Old 09-11-2012, 12:09 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Default Remote Start Problems?
Has anyone's remote start gone out? I had an issue a couple days ago involving my programmer and battery, and now my remote start wont start the car. It recognizes it, but doesn't make the move to turn the engine over when it should. Any clues?
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 09-11-2012, 05:06 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Default Re: Remote Start Problems?
If it is a GM keyfob autostart, you are probably going to have to go back to a dealerhsip and have them reprogram it for you.
I'm using a Viper, so not sure if I can help. I can tell you that it could either be the button sensor in the keyfob wore out, or something happened to deprogram the signal for autostart. If they reprogram it at the dealership and it doesn't work, then you know it is the button on the fob and you will probably have to replace that cheap piece of S**t. On top of that, they will rape you violently without protection for that FOB, so stretch out good before that visit just in case.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 09-11-2012, 06:28 PM
tyler1bo's Avatar
Well great..that sounds comforting. And yes it's the fob start.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 09-11-2012, 07:13 PM
Flare's Avatar
Flare Flare is offline
Flare is on a distinguished road
Have you tried to reprogram the FOB via the DIC? I had to reprogram 2 FOBs when i bought my H2 - came with only 1 set. I bought the FOBs on ebay for about $30 each and avoided a trip to the dealer.
2008 Solar Flare SUT, 6" lift, Cognito UCAs, AMP Steps, 38X15.5X20 Toyo Open Country M/T, Airaid CAI, Magnuson S/C, Dynatech LT Headers + High Flow Cats, Custom Exhaust, 3.73(I know!)
Old 09-11-2012, 08:51 PM
dvl57's Avatar
dvl57 dvl57 is offline
dvl57 is on a distinguished road
how do you manually program the remote?
I have 1 key fob remote, and an extra one...which isn't programmed.
Don
2008 H2
Billy Boat Exhaust
Old 09-11-2012, 10:01 PM
Flare's Avatar
FYI - you'll have to reprogram both remotes at the same time.
(from the 2008 owner's manual)
1. Press the vehicle information button (second one on the DIC) until
PRESS V (check mark) TO RELEARN REMOTE KEY displays.
2. Press the set/reset button until REMOTE KEY
LEARNING ACTIVE is displayed.
3. Press and hold the lock and unlock buttons
on the first transmitter at the same time for
about 15 seconds.
On vehicles with memory recall seats, the
first transmitter learned will match driver 1
and the second will match driver 2.
A chime will sound indicating that the
transmitter is matched.
4. To match additional transmitters at this time,
repeat Step 3.
Each vehicle can have a maximum of
eight transmitters matched to it.
5. To exit the programming mode, you must
cycle the key to LOCK/OFF.
Hope this helps.
Old 09-12-2012, 05:44 PM
tyler1bo's Avatar
I'll try reprogramming it, that may be the issue. Btw, post some pics of this jewel you're ridin it. Looks like a good mod list so far!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 09-12-2012, 09:16 PM
Flare's Avatar
Good luck and will do on the pics. I'm out of town so it'll have to wait until I get back. I did review your machine on some other threads - very nice, awesome professional pics!
Old 09-12-2012, 09:49 PM
tyler1bo's Avatar
haha thanks man! Glad you think they're professional! They're just me being bored.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 09-13-2012, 12:08 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
If you have any trouble codes set in the ecm it will disable the remote start function, lights will flash but will not start. Scan for codes, clear them and try again
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-13-2012, 01:38 AM
tyler1bo's Avatar
That was it! I've had a PO449 code the past few days, this morning I started the truck and the check engine light never came on. Idk why, it's been on for awhile now. But I just went outside and used my key fob and it started right up. It's weird :/
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 09-13-2012, 04:24 AM
HUMTECH's Avatar
Cool, glad i could help
1998 Chev Z71
