Old 07-01-2003, 03:24 AM
BADRAP BADRAP is offline
BADRAP is off the scale
I noticed something the other day when I opened the hood....There is no light under there... Anyone think about this or has done this already and have some pics? I am curious as to what to use and where to place, wire, etc.... Just a thought....
BADRAP
03 H2, Lux, Pewter
H2 Club - Houston Chapter..
badrap@sbcglobal.net
BADRAP
03 H2, Lux, Pewter
Old 07-01-2003, 11:43 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
Hey BADRAP:
I may take my old DRL's and stick them under the hood with a switch.
Actually, the early H2's had a hood light in the center of the hood, see pic. That's GM...saving the big bucks and taking away our everyday conveniences.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 07-01-2003, 12:31 PM
TBarrow TBarrow is offline
TBarrow is off the scale
Yeah I also have the light.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Alcoa Wheels, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, 2-7" screens in headrests with DVD player and TV Tuner.
Old 07-01-2003, 01:23 PM
Grim_Smoker Grim_Smoker is offline
Grim_Smoker is off the scale
I don't have a light either, really cheeses me off. I've though about just mounting a tiny cheap mirror or other reflective surface to the inside of the hood, then just turning on my roof lights, should brighten up the bay .
-Grim
2003 Sunset Metalic Orange H2 - Breathless Stage 2B, HID's, Gobi Rack & Ladder.
2003 Millenium Yellow Z06
2004 Black Silverado SS
Old 07-01-2003, 02:02 PM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
I have two lights under my hood .... one like in the photo and another down near the bottom of the oil dip stick mounted somewhere either on the frame or on a support of some sort ... I have a very early H2 .. #146
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 07-01-2003, 04:30 PM
Circuitguy
Can anyone get me the part numbers off of the stock hood lights. I want to order one for my H2. BIG-C
First American Properties Inc. 916-858-2383
White 03-H2-LUX
Old 07-01-2003, 05:26 PM
Thanks for all the replies... I think I will have to look into mounting a light under there... I think that I found what I was looking for at a website today... I guess I will order and see what I can do with it..
BADRAP
03 H2, Lux, Pewter
Old 07-01-2003, 05:54 PM
Mike97ZJ Mike97ZJ is offline
Mike97ZJ is off the scale
Hmm, that's funny. Older GM trucks ('88-'98) had a removeable underhood light that had a 10 or 15 foot reel-in cord on it. Maybe you could get one of those from a boneyard or the dealer.
1997 Grand Cherokee TSi
It\'s got some lift, skids, and rock rails, among other things.
*member of the \"No Hummer Krew\"*
Old 07-01-2003, 06:10 PM
Klaus's Avatar
Klaus Klaus is offline
GM H2 underhood light:
LAMP, U/HOOD 12450086
Klaus
Old 07-01-2003, 07:18 PM
Circuitguy
Thanks Klaus...C
White 03-H2-LUX
Old 07-01-2003, 07:22 PM
Circuitguy
12450086 comes up as a hood light at gm parts direct. Sells for about $8.00 each. Now thats affordable. I hope it includes all that is needed to mount it and hook it up. BIG-C
White 03-H2-LUX
Old 07-03-2003, 01:27 AM
blg615 blg615 is offline
blg615 is off the scale
[quote]Originally posted by PhilD:
Mike, The H1's have a little light on a reel-in cord too, a good idea, although it isn't very bright, but better than nothing.
QUOTE]
go to usahummer.com Then to accessories. scroll down to Reel Lamp Kit $42
Old 07-03-2003, 09:02 AM
Hey Blg, I went to the web site and realized I visited that dealer while in Atlanta. I was actually about 200 miles from you on June 22. I was invited by Carl Black to their Hummer Happening and went off roading at the base of the Blue Ridge Mountains. were you there by chance. I do have pics and will post soon. The great thing was that I was supplied a new Hummer for my driving pleasure.
Old 03-23-2013, 05:35 AM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
Default Re: Anyone think about installing a light under the hood?
Well, I did it.
I got to thinking about why H2's don't have any sort of lighting like they did back in the early days. I liked the retractable GM light unit they had in the trucks so I ordered one off of eBay and when it came in, I installed it and it works great!! ($30)
First, I had to look for a place that would be functional without having to modify anything under the hood. The best place I found was on the passenger side between the factory air intake filter housing and the radiator overflow tank. I drilled 3 holes after marking them on side wall of the engine compartment, used 3 sheet metal screws to mount the retractable light.
Then came the wiring; it only has the 2 wires for it so I bought some 24 gauge wire and 1/4" wiring loom to cover it all and spliced in a 5 amp in-line fuse on the other end by the battery. I ran the wiring across the front of the engine compartment atop the radiator shroud behind the mounts and around the battery. I then placed a wire terminal loop on the ends of both wires and attached them to the battery.
Then came the testing. Once I had the wires neatly loomed, wire tied, and tucked away, I walked back over to the passenger side and pulled out the light and flipped the switch and BINGO!! We have light under the hood of the H2!!!!!
This was an easy job and not much $$ for a couple hour mod. Fun to do too! Just thought I'd share this with the H2 community so they all know its possible to do.
fyr145
Old 03-23-2013, 02:27 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
where's the pics!!!!???
Old 03-24-2013, 04:42 AM
fyr145's Avatar
Moderator
I was planning to take them soon!!!
(if I can learn how to get them posted on here)
Old 03-30-2013, 05:54 AM
Thumper Thumper is offline
Thumper is on a distinguished road
Even if the H2 came with a light I think it would be useless since the hood opens so wide and to the front. Harbor Fright sells small LED battery operated portable lights that both a hook and magnet for under $3 each. they work great and you can move them around into the right angle or position.
http://www.harborfreight.com
