Old 05-15-2013, 02:50 PM
Egan's Avatar
Egan Egan is offline
Egan is on a distinguished road
Default Member advice on tire/wheel combo
Okay, all of the parts are here for my mini lift kit - Cognita UCA's, Bilsteins, Keys, Rear coil spacers, front endlinks - and I'll be installing it this weekend. Now I need to decide on wheels and tires. I've kicked around several options and would like to hear some opinions before I pick one of them.
Option 1 = Keep stock wheels, add 37x12.5x17 tires
Pros = Only buying tires, cost around $1,700 for 5; can paint stockers black
Cons = rubbing at full lock, still on stock wheels
Option 2 = ATX Thug Teflon coated wheels in 17x8.5 (+15 or -6 offset) with 37x12.5x17 tires (I had Teflon Fuels on my last truck and they were great wheels)
Pros = easy to clean wheels, wheels pushed out a bit and should avoid rubbing
Cons = 5 wheels and tires cost $2,600
Option 3 = H1 take-offs
Pros = cheap ($1,200) for tires and wheels
Cons = Heavy, availability may be limited for 16.5 tires down the road
A lot of the tires are around the same price, so I am looking at Hankook MT's, Cooper STT's, BFG AT KO's, Toyo's, and Nitto's - all in 37x12.5 (except the Toyo's which are 13.5 wide).
I'd really like to get the Rock Monster Beadlocks for wheels, but at $400 a pop it brings my total up to $3,600.
Another option is to ditch the spare. My '01 BMW M Coupe (now sold) didn't have one and my '13 Boss 302 doesn't have one either. But with my luck, I would get a flat simply because I chose not to carry one.
My Sport Luxury Utility Truck (SLUT) is a mostly daily driver that will see mild offroad work for hunting, camping, and 4x4 trips.
I appreciate the advice and opinions.
2005 H2 SUT
Moog Pitman & Idler
Cognito Support Kit
Cognito UCA's
Kryptonite Tie Rods
Kryptonite Swaybar End Links
Traxda Keys
Traxda Rear Coil Spacers
Bilstein Shocks
TruCool Tranny Cooler
Corvette Servo
Gobi Ranger Roof Rack
Gobi Bed Rack
Pioneer AVIC-Z110BT: Nav, Bluetooth, iPOD, Backup Camera
Valentine 1 w/ Blend Mount
ATX Artillery 17x9 Teflon
Toyo Open Country MT 37x13.5x17
Old 05-15-2013, 07:02 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: Member advice on tire/wheel combo
the H1 wheels are awesome and a full setup is dirt cheap. However price some retail 16.5 tires and you'll be blown away at the price! I never pulled the trigger on them because my worry is the surplus tires all being bought then having to spend nearly $3k for just rubber..
Old 05-15-2013, 09:18 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Option 1 with the BFG AT KO tires. Both will serve you well and unless you off road a lot the occassional rub won't matter.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
