Old 04-30-2014, 06:56 PM
RJ03 RJ03 is offline
RJ03 is on a distinguished road
Default 2003 H2 poor acceleration when cold & warm
Hi, I'm having poor acceleration when cold and even when it's warm. No trouble code light. Recent plugs, wires, fuel and air filter. I also cleaned the MAF with a MAF cleaner spray. I did notice a little oily/carbon build up at the throttle body. Haven't cleaned that yet, but will once this rain stops. While its cold, I press the pedal to like half to three quarters to the floor and horrible acceleration. As I start to let off the pedal it actually feels like its accelerating better. I do run fuel system cleaner through the system on occasion, use quality gas. I'm baffled. Thanks in advance for any suggestions, recommendations, etc. RJ03
Old 04-30-2014, 07:15 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: 2003 H2 poor acceleration when cold & warm
Unplug your maf sensor and try it, you will set codes but that will determine if maf is reading incorrectly. If its better you need maf sensor.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-30-2014, 07:56 PM
Okay thanks HUMTECH. I'll drive it with the MAF unplugged. I better invest in a scan tool to reset light.
Old 04-30-2014, 08:49 PM
HUMTECH, just curious, if I needed a new MAF wouldn't it triggered a code turning on the engine light? Or not necessarily? Thanks, RJ03
Old 05-01-2014, 12:00 AM
HUMTECH's Avatar
Not always, seen many that cause lack of power yet the scan data readings are correct.
1998 Chev Z71
Old 05-01-2014, 01:15 AM
Okay, had a feeling you were going to say that. Thanks for your help.
Old 05-01-2014, 01:31 AM
jsbihn jsbihn is offline
Moderator
subbed in to see the results
'03 H2 (name: Big Gulp)
