Old 01-23-2015, 05:52 PM
jsbihn jsbihn is offline
Moderator
Default Are wheel adapters/ spacers safe?
Hey all
I am looking to put a 1-2 inch wheel adapter/spacer on my stock wheels. I figured with a 3 inch key/spacer lift and 38 x 14.5 x 17 that I would need them to clear the suspension. (please tell me if I am wrong).
These adapters are the kind that you bolt to the oem hubs and they have their own studs you would bolt the wheel to
So...
My question is are they safe?
I have heard that some have done them, and others wont.
I would like to heard from both please.
I am not really a hard core off roader so, are they safe? Do they make hubs or parts wear faster?
I will also be doing an alignment after they are done, and most of the suspension and steering components have been replaced with Moog as of this and last weekend
What do you think?
'03 H2 (name: Big Gulp)
Old 01-23-2015, 08:39 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Re: Are wheel adapters/ spacers safe?
In my experience no. Not very safe. My brother had them on his f250 with 37x13.5s and one broke off while he was cruising at 70 mph
2008 Hummer H2 Lux Ed. Sedona Interior. XD Spys wrapped in 37x13.5 Toyo Mtsss.
Old 01-29-2015, 08:50 PM
Stellar Stellar is offline
Stellar is off the scale
I've ran spacers on my H2, Dodge diesel, and TJ wangler specifically built for rock crawling for over a decade with no issues. The spacers will make hubs wear faster, but are generally stronger than the hub themselves. Hubs and steering components on the deuce should be checked regularly anyhow as the stock steering set up is weak / garbage.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
