Old 07-29-2014, 02:21 AM
dna dna is offline
dna is off the scale
Default Help - changed my plugs now H2 runs like @#$%
After 200kms I thought it would be a good idea to change the plugs and wires for the 1st time. Bought the iridium (41-110) and OEM wires. With doing only limited googling, I thought these were supposed to be gapped at .06mm so I did that (they were 0.04mm out of the box).
After installed these new plugs, the idle was smooth and revved nice. Took it for a drive and the truck could barely get over 100 km/hr. After a few minutes I got P0151 (maf sensor) and p0300 (random misfires).
So I pulled all plugs out again and regapped back to 0.04. Installed them, but same thing. Could barely get over 100km/h and same 2 obdii codes.
Could I have damaged the plugs when I first gapped them? My method was sticking a flathead driver into the gap and lifting up - could this have damaged the iridium tip?? Is there anyway I can tell if the plugs are bad other than buying a whole new set?? BTW - I dropped one of them about 3' onto a concrete floor - when it first happened I looked at it and it looked fine. Could that have damaged that one, and is it possible if I have only 1 bad plug that I'd get these symptoms and codes?? I would have thought if only one plug was bad that the p0300 would have given me a number in the last digit to tell me which cyclinder is misfiring - doesn't p0300 mean all (or more than 1) cylinders are misfiring??
Old 08-01-2014, 09:23 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Re: Help - changed my plugs now H2 runs like @#$%
My bet is you either bumped the plug at the MAF during your plug swap or there is a break in that wiring. Without the MAF signal it will do exactly what you described.
Old 08-02-2014, 03:48 AM
dna dna is offline
Checked the maf plug and it was fine. Still have the issue. I guess it could be a coincidence and my maf sensor has gone bad. Is there a way to test the sensor?
Otherwise if maf is good and maf plug well connected, any other ideas?
Could it be my cat. I have one that is going bad. Been looking for a replacement for a few weeks now. Though prior to the plug swap, only issue I had was rattlin (no codes). Maybe with the new plugs and wires, with the extra power it was enough to fully plug my cat. Heard that a plugged cat will give p0300 codes - though would that also give the maf code?
Old 08-02-2014, 09:37 PM
MAF itself could be bad or the wiring from it going to the computer. My only other guess would be a forward O2 sensor. If your cat was bad the rear O2 would catch it and that's only for emissions anyway, the forward O2 is for Air/Fuel. The codes are your friend.. it would not have thrown a MAF sensor code unless it was out of range or not receiving feedback from it. Unplug your MAF sensor and drive it. If there is no difference I would replace it.
Old 01-30-2015, 04:58 PM
inputapmech inputapmech is offline
inputapmech is on a distinguished road
I think your spark gap is 1.02mm.... That might be the problem
Old 02-02-2015, 01:09 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
1.02mm is the same as a gap of .04 and that is what the plugs should be gapped at,, suspect just coincidence but probably MAF problem
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 02-15-2015, 10:37 PM
Did you ever figure it out?
