Old 01-09-2004, 08:29 PM
Klaus's Avatar
Klaus Klaus is offline
Just an update on installing XM in your H2:
If you are planning on using the Soundgate adapter (PIOGM1V3), you should know that the Pioneer GEX-P910XM tuner appears to be discontinued. See this link to Crutchfield:
http://www.crutchfield.com/cgi-bin/S-m8Ni4lKaMgQ/prodview.asp?i=130P910XM&g=79900&a=&s=0&cc=01&id=o ther_items
The reason appears to be what XM is now doing. XM has partnered with Blitzsafe, another adapter maker that has a much better reputation then Soundgate. XM is selling a "package" that they call "XMDirect" which is the tuner and the adapter sold together. Right now, it is available for BMWs. The current thinking is that XMDirect for GM will be available in March or April.
XMDirect has the promise of working better than the Soundgate adapter. It should be more reliable, and might display more characters, etc.
The down side is that this is all the adapter will do, connect XM to your stereo. No CD changer or AUX input.
Anyway, if you are planning on buying the Pioneer GEX-P910XM and connect it to a Soundgate adapter, you might want to go ahead and buy one while you can.
Klaus
Skull & Bones Member since 2003
