Old 03-21-2008, 02:17 AM
alex7296 alex7296 is offline
alex7296 is on a distinguished road
Cool How to adapt ctis to aftermarket rims
I have a set of 40'' tires on 17'' rims that I want to put on my 2002 H1. I will be installing a 2'' susp. lift due to ease of install. Just not sure how to retain CTIS on different rims.
Old 03-21-2008, 07:58 PM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
Default Re: How to adapt ctis to aftermarket rims
good luck... honestly this isn't really advisable for drilling into a rim... often it is done on the H2 rims that are put on the H1's but if you want a alternative rim.... try Cepek.... designed specifically for the H1....
Old 03-21-2008, 11:25 PM
audiofetish's Avatar
I don't think he meant internal CTIS.
You can get the external CTIS lines from most Hummer parts stores such as rubberduck4x4.com and bluehummer.com It will run you about $500. If you do any offroading make sure you get wheel protectors.
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 03-22-2008, 12:07 AM
Talking Re: How to adapt ctis to aftermarket rims
Yes, I see that there are valve stem adapters but I'm not sure this is the right way to go.I want to upgrade the outer lines , I'm not too crazy about rubber, I'd like to get S.S braid if possible. Drilling into the valvestem area doesn't bother me as long as I can get the right fittings for the rim. I'd hate to run without the CTIS just to have cool rims. When I purchassed the rig the rims came with it , the previous owner found out you can't just put 40'' tires without a lift and gave up.
2002 H1
2006 H2
1970 Chevelle Drag Car
1954 Ford
1979 Trans am
