12-28-2005, 07:30 PM
Still in progress...
Plans are to dump the tubes for Amp power steps, black out door handles and the grill/mirror caps, add black gas cap door.
2
3
12-28-2005, 07:38 PM
I like it!
Do not forget to say size/brand of wheels & Tires.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
12-28-2005, 07:59 PM
I like it!
Do not forget to say size/brand of wheels & Tires. </div></BLOCKQUOTE>
JAX wheels w Mickey Thompson Baja Claw Radials (LT325/50R20)
Tomp, would you tell what's the backspacing of that JAX 20" wheel and can you measure how much that tire does stick out?
Thanks!
12-28-2005, 08:23 PM
Damn W1N, you guessed it right on the money.
Jax wheels suck, as I found out the hard way. The bead around the outer part of the rim is deformed and lots of blemishes/pits on the wheels. I guess you get what you pay for on these wheels because they were cheap. I plan on mudding with lots of rocks in the mud, so I dodn't want to destroy some high dollar wheels.
Tires stick out pretty far at about 2" outside stock flares.
Backspacing 4.5 and offset is -25. There is some slight rubbing, but only because they are so wide that they rub when wheel is turned all the way to one side. Other than that, they rub the same as my stock ones did when off roading.
I really likes Boss Hoss' setup and took his advice on wheel/tire selection.
12-28-2005, 08:27 PM
BTW, gas mileage is noticably worse and not sure how bad it is just yet. I can feel loss in acceleration. Not sure if it's weight of wheel/tire combo or friction from tires or all of the above.
Tires are very quiet for mudders. Only noise is when slowing down at stops. Little vibration when starting off, due to knobbies on tires.
12-28-2005, 09:04 PM
Little vibration when starting off, due to knobbies on tires. </div></BLOCKQUOTE>
Did you get an alignment yet?
12-28-2005, 09:59 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Klaus:
Did you get an alignment yet?  </div></BLOCKQUOTE>
Is that a TIP?
12-28-2005, 10:13 PM
 </div></BLOCKQUOTE>
Looks good. Now rip off the dealer letters.
12-28-2005, 10:37 PM
Thx... Yep, Sewell dealership letters got to go.
12-28-2005, 11:09 PM
Thx... Yep, Sewell dealership letters got to go. </div></BLOCKQUOTE>
Sewell is bad.
DO NOW OR BANNED!!!
12-28-2005, 11:13 PM
Set up looks cool. I especially like the rim/tire configuration. They'd look mighty nice color matched to the body color.
12-28-2005, 11:21 PM
Set up looks cool. I especially like the rim/tire configuration. They'd look mighty nice color matched to the body color. </div></BLOCKQUOTE>
Yeah... too bad he's ghey.
Dennis said rim.
12-29-2005, 05:16 AM
looks nice the way it is but if your gonna black out everything id like to see the rims in that black crome. also what kind of light bar is that looks clean and simple.
12-29-2005, 06:06 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rocketw19:
looks nice the way it is but if your gonna black out everything id like to see the rims in that black crome. also what kind of light bar is that looks clean and simple. </div></BLOCKQUOTE>
looks like a delta 10x lightvar
12-29-2005, 12:15 PM
Looks pretty good! What's the wheel width?
12-29-2005, 01:56 PM
Looks sweet....im thinking that is a 13.50 width and a 10in rim(partially because thats my setup  ). I think the wide wheel/tire combo sets it off.
