11-23-2005, 02:23 AM
Just wondering if anyone knows the difference between the PIAA Platinum SUPER WHITE 9007 and the PIAA EXTREME WHITE 9007?
Thx
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Thx
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
11-24-2005, 01:15 AM
Anyone??
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
11-24-2005, 01:34 AM
Look at the Kelvin Temp.
Lower Kelvin temps = more light.
Higher Kelvin temps = more white color.
So - the Extreme White is a 4000 K bulb.
The Platinum Super White is a 3800 K bulb.
In theory, the Platinum Super White would be slightly brighter at the same wattage.
At the bottom of this web page, you'll see a chart comparing true Xenon HID assemblies with different colors. At 4200K, the light given off is the brightest in lumens. At 10000K, the light given off is 1/2 of the 4200K bulb.
http://24.248.84.138/hummers/headlig...visionplus.htm
The same principles apply to Halogen/Xenon filament bulbs.
HTH,
Steve
M101A2 Trailer
11-24-2005, 02:10 AM
Thanks Beastmaster
I added this to My favorites. I usually let Dragon guide Me on this stuff. But, the first chart I have seen for Myself.
Would You please give Me some info about My setup for now?
What kind of light will I get from a roof light bar with 5-55 watt quartz halogen H3 bulbs. They have a light blue colored lens over them which has a tendecy to make them look whiter I think.
TAZ
11-24-2005, 02:12 AM
Thanks Steve  (get it, sunglasses, brightness!!!)
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
11-24-2005, 04:19 AM
That's a hard one. Ususally the bulb (if it came from a top end mfg) will have the wattage, the temp in K, and the model #.
If it's a really really light blue, I'd hazard a guess they are in the 4200 to 5000 Kelvin temp range.
As for light - each of your lights are equal in brightness to a single headlight. So - you should see about 2.5x the headlight outputs with what you have now. That (combined with the stock lamps) should light up stuff really well - night runs, anyone?
The lighting in your roof alone should put out about 7500 lumens worth of light. Not bad - that's equivalent to one of those huge arc area work lamps that sit on fire trucks and require 110 volt. It also exceeds most handheld light measurement systems.
-Steve
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HUMMERcustoms.com/TAZ:
Thanks Beastmaster
TAZ </div></BLOCKQUOTE>
M101A2 Trailer
