11-20-2002, 08:20 PM
My H2 AC is very noisy when it was turned on. The exhaust air is ok. It seems to me like the fan bearing has problem. Talked to dealer, they say that all H2 have that problem, and it is normal.
Additionally, my wind shield wiper leaks. Talked to dealer, and they say that "engineers" at Hummer is working on replacement parts.
I like to hear from other H2 owners if you experience same problems. I love my H2 though. -Tuan-
11-20-2002, 08:48 PM
Hey Tuan: did you buy at Daughtery Hummer? That's where I got mine too!
My rear windshield wiper did leak as the reservoir was filled REALLY FULL. Use it a couple of times to take the level down, and it'll be fine. Don't overfill and it won't recur (hasn't for me) The bigger problem was that green stain left on the black license plate area of the tailgate. I used a plastic scrubber sponge GENTLY and got all the goo off, then used 2001 spray to return the black color. Worked like a charm. Almost five months with no more problems.
As for the AC, I've not had any trouble with loud fans, so I can't help there.
Kelley
11-20-2002, 08:59 PM
AC on AUTO sometimes uses high fan which is loud, depending on temp. Just manually turn down the fan. A matter of setting, I would not consider that to be a problem.
I have no windshield wiper leak.
11-21-2002, 12:44 AM
I would agree that on high speed, the acfan is too loud. You can not hear the Bose.
"Follow the white rabit" .........Matrix 1999
\"Follow the white rabbit...\" Morpheus 1999....... It is finished.
11-21-2002, 02:33 AM
Kellymac, I did bought the H2 at Daugherty.
Thanks for your responses, but the AC for my H2 is noisy even at low speed. It sounds like the fan touching something. -Tuan-
11-21-2002, 11:58 PM
Don't let the dealer skate on his/her responsibility. Let them know that you're going to call the GM customer service line and tell tha they said it was normal. Dealers don't like to get calls from higher up about these kind of things.
11-22-2002, 12:09 AM
Just for a point of reference, mine is ok. Not loud and purrrrrrrrrrssssssss like a kitten. [img]/infopop/emoticons/icon_smile.gif[/img]
Get it fixed, you paid too much for the vehicle not to be right. But that's just my opinion.
I have not had any problems with mine. The day I bought it it was raining and it rained hard. No leaks and everything, including the sunroof, worked well. [img]/infopop/emoticons/icon_biggrin.gif[/img]
Hee
HeeeeeeeeHawwwwwwwwwww
