Old 02-03-2006, 12:15 PM
BB BB is offline
BB is an unknown quantity at this point
Does anyone know if the tire pressure sensors can be fit on aftermarket wheels and work ?
BB BB is offline
Old 02-03-2006, 02:27 PM
evomind evomind is offline
evomind is an unknown quantity at this point
yes they can
i posted in a similar thread though that with my 35" ssr's, the right front passenger side wont pick up the sensor from the tire. the other 3 do however.
i think itll work from any stock sized tire and even oversized ones that arent too aggressive.
Old 02-03-2006, 03:26 PM
Klint's Avatar
Klint Klint is offline
This depends on the wheel.. I know this because I hd this problem when I was looking for wheels some didn't support the T/S
Klint T.
2007 Black Lux, Blinged out
Old 02-03-2006, 06:35 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by evomind:
yes they can
i think itll work from any stock sized tire and even oversized ones that arent too aggressive. </div></BLOCKQUOTE>
That's strange. I would suspect the sensor is bad, especially since the antenna is built into the BCM and that is on the right front.
If a sensor fits a rim, it should work. All it is doing is monitoring pressure.
Old 02-03-2006, 10:44 PM
BB BB is offline
Thank you for reply. I will get them and ask the shop to install them.
Old 02-05-2006, 10:22 PM
fstop,
the dealer switched the sensor to my spare after they couldnt get it to work on the one that was there. then they put on a stock sized tire/rim and the sensor worked so they stopped looking for a problem...
any suggestions?
