Old 09-12-2005, 04:43 PM
rocketw19's Avatar
first off im a newbe to h2s and have searched this fourm for my anwser but not real clear. my question is i dont wanna lift my 06 sut at all but i want the biggest tire rim combo i can fit with out rubbin. i think its a 325/60/20 but i realy like the way the 335/55/22 looks in the "wheel opinion" thread. the bfg tires are what i like so far not sure on rims yet. thanks for your help.
rocketw19's Avatar
Old 09-12-2005, 05:28 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
To calculate tire sizes i like to go to this site:
http://www.miata.net/garage/tirecalc.html
The 325/60-20 has a diameter of 35.4 and the 335/55-22 has a diameter of 36.5. The toyo M/T is being run by many people and you can look up old threads using the find button on people that are running the 37's as to if they rub or not. The consensus i have drawn is most do some dont--or some say they dont. The 37x13.50-17 is 37.1 in. tall(according to http://www.toyo.com) so the tire you are looking at is actually slightly shorter, but potentially wider. Another aspect you will want to look at is the offset of the rim. The find button on this will give you lots of information.
I like a more "squared" tire than the BFG so i went the the ProComp extreme all terrain in a 35x13.50-20. I find the BFG's balloon out to much between the rim and the top of the tread. Mickey Thompson also makes a nice square wide tire(i think its the baja radial atz). I also was thinking i wanted the biggest tire rim combo without worrying about rubbing and other complications but as i researched i decided to settle on what i knew was a safe bet(35's instead of 37's) but im really happy with the result even though i thought i was settling.
Here is what the 35x13.50-20 ProComp on Kaotik NT-1's look like:
The Kaotik rims are wide(20x10) and the tires are wider than most 35's so the affect is WIDE.
Old 09-12-2005, 05:49 PM
rocketw19's Avatar
ya i seen you pictures in another thread and liked it alot. i was checkin out the same rims you have. i also like the foose spank witch have the same look. do you know what would need to be done to get 37s under there?
Old 09-13-2005, 02:15 AM
37"x12.5" should fit fine with little to no rubbing.
Old 09-13-2005, 12:55 PM
H2JP H2JP is offline
H2JP is off the scale
http://elcova.com/groupee/forums/a/t...1/m/4181049631
Heres my 37x12.50-20's. Some rubbing but I love em.
Old 09-14-2005, 12:48 AM
BAD_SUT BAD_SUT is offline
BAD_SUT is an unknown quantity at this point
here's my pic of 22" with the Nitto grapler's
05 H2 SUT
05 BMW 645CI
06 ZO6 C6
07 CADILLAC ESCALADE
Old 09-14-2005, 01:56 AM
H24U H24U is offline
H24U is off the scale
What is your offset with the 22"? What type of wheels are they?
Old 09-14-2005, 04:18 AM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rocketw19:
first off im a newbe to h2s and have searched this fourm for my anwser but not real clear. my question is i dont wanna lift my 06 sut at all but i want the biggest tire rim combo i can fit with out rubbin. i think its a 325/60/20 but i realy like the way the 335/55/22 looks in the "wheel opinion" thread. the bfg tires are what i like so far not sure on rims yet. thanks for your help. </div></BLOCKQUOTE>
If you end up wanting those 335/55/22 BFG's go get them now. they have been selling like crazy and it is a limited edition, so there is no guarantee that you can get them anywhere soon. I ordered mine like 3 weeks ago and it took a battle to find one set! Finally BFG found a set in Ontario, CA.
Old 09-14-2005, 05:58 PM
4churchill is off the scale
The biggest we do @ the dealership is 22" withe the Terraa Grapplers
www.HUMMERNut.net
Old 09-14-2005, 06:29 PM
Boss Hoss's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by W1N:
If you end up wanting those 335/55/22 BFG's go get them now. they have been selling like crazy and it is a limited edition, so there is no guarantee that you can get them anywhere soon. I ordered mine like 3 weeks ago and it took a battle to find one set! Finally BFG found a set in Ontario, CA. </div></BLOCKQUOTE>
So what happens if you have a blow out, or anything else that requires you replacing 1 tire? Looks like youll find yourself buying 4 tires in a differnt brand....this just doesnt make sense to me.
Old 09-14-2005, 10:46 PM
W1N's Avatar
W1N W1N is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Boss Hoss:
So what happens if you have a blow out, or anything else that requires you replacing 1 tire? Looks like youll find yourself buying 4 tires in a differnt brand....this just doesnt make sense to me. </div></BLOCKQUOTE>
I'm sure thay will have them in production. It seems like these tires are so popular. Right now they just are sold as they come in...
