Old 10-27-2005, 01:39 AM
Bondage Bondage is offline
Bondage is off the scale
What tires and sizes are you all running - and what do you recommend airing down the OE Goodrich AT's to off road? (for deep sand and lotsa rocks) Thanks for the input!
Sean
Sean
Old 10-27-2005, 03:34 PM
Stock 35 ATs and 37 MT/Rs work well at ~18 PSI </div></BLOCKQUOTE>
What's the risk of popping a bead at those pressures? I know it is increased, but does it ever actually HAPPEN to you guys? And is the risk to the lower, more exposed sidewall great or not of concern? I had mine down to 22psi when the sharp rock shredded my sidewall. Think that was just a freak happening, or what? I KNOW it was driver error that slid me over into the sharper, higher rocks at the edge of the trail. But I DON'T know if it would have sliced like that if I were not aired down. You guys have far more experience than I, so share more with me?
Sean
Old 10-27-2005, 04:04 PM
We've been all over Moab and Colorado with ATs and MTs around 20 psi. Never had a bead pop. I don't think the risk is high at that pressure. When you start going to 12-15 psi the risk is much higher.
Old 10-27-2005, 09:33 PM
We've been all over Moab and Colorado with ATs and MTs around 20 psi. Never had a bead pop. I don't think the risk is high at that pressure. When you start going to 12-15 psi the risk is much higher. </div></BLOCKQUOTE>
Very good. Thanks. Now for the $64k question - what tire (35") gives the best balance of on and off road performance? In other words, is most capable off road while not sounding or feeling like a freight train on the interstate? I have been told by TWO tire dealers in my area that the stock OE Goodrich tires are about as good as it gets. Now it is hard to argue with them, 'casue I know they'd like to sell me some tires but feel they are being honest. IS there a better choice?
Sean
Old 10-28-2005, 03:42 AM
H2Finally's Avatar
Sean, I ran 31k on the stock ATs. Offroad everywhere around here except Pismo, 21psi was PERFECT. I had never poped a bead nor a cut, nor even a flat for that matter . Imho your sidewall cut was bad luck.
I ugraded to 37"MTR -- and THEY SUCK!! .. at least on H2s . Those tire guys are right. For our terrain, the BFG ATs are top of the line -- though I would get them in 37"..
Can BLING Get You Home?
Old 10-28-2005, 03:52 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
Sean </div></BLOCKQUOTE>
I love my new Toyo MTs. Great offroad and perfect on pavement(smooth as glass at 100mph).
Old 10-28-2005, 03:53 AM
rodster rodster is offline
rodster is off the scale
The Hummer X Club has a few tech docs that may be helpful. http://www.*******club.com/tech.html
\'05 SUT
