09-02-2004, 04:33 PM
So, when you go off- road, what does everyone do with their gear? I take the dogs with me almost every time, so I was worried about the gear sliding around and into them. And if for some reason I was to top over, than all of that gear is loose also.
So my questions is, what does everyone elso do with their gear? I made a boz and carpeted in and through some basic hand tools and receovery gear and first aide gear.
09-02-2004, 04:34 PM
One more... and the box is secured to the floor too.
09-02-2004, 04:39 PM
Hey, that looks nice Tim. Good job. Probably better then most you could buy.
09-02-2004, 04:49 PM
09-02-2004, 05:13 PM
Nice! What did you use to cut out the foam shapes for the tools? Looks like nice cuts.
09-02-2004, 05:16 PM
Seth, it is anchored to the floor. If you look at the foam, their is a white small first aide kit. to the top left corner their is a pillar in the middle. On the floor is where the third seat used to clip into the foor. I placed to hooks ans crewed them into the pillar, the pillar is screwed to the box. it doesn't move at all. as far as tie downs on top, I have four pull rings I have not put in yet. i want to have them flush mount with the carpet. than I can mount my H2O tank and tool box in there too.
BTW, anyone have instructions on how to change out the tie rod. I would like to print that out and laminate it and throw it in the box too.
With carpet and materials it was about a thousand dollars cheaper than the truck vault.
09-02-2004, 06:59 PM
If it's to protect your dogs, you might want some sort of latch to make sure the hatch stays shut if you have the misfortune of rolling over.
