Old 10-09-2005, 11:08 PM
tomp's Avatar
tomp tomp is offline
Does the Bully locking pin work here? Before I order one, I'd like to verify it will work with the thick metal of the winch's cradle?
For NE1 that uses the Bully single sided locking pin for their winch, can you please measure the thickness of the steel that the pin has to go through for me?
I would have preferred to order two of them that would use the same key for both. However, my rear ball hitch receiver is solid steel and not hollow.
tomp's Avatar
Old 10-10-2005, 12:36 AM
rodster rodster is offline
rodster is off the scale
</div></BLOCKQUOTE>
Others do use the Bully pin.
http://elcova.com/groupee/forums/a/t...001#6471039001
I use a locking pin from Master Lock . Does the same job and does it well for around $15 or less.
\'05 SUT
