Old 11-09-2003, 12:34 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I realize this info my be in the manual but why would it say the road may be icy if the temp said 37F?
NJ H2's Avatar
Old 11-09-2003, 01:38 AM
TBarrow TBarrow is offline
TBarrow is off the scale
because of bridges. They freeze first as the air passes under because the don't have a soil base for insulation as normal roads.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, 2-7" screens in headrests with DVD player and TV Tuner.
Old 11-09-2003, 01:51 AM
NJ H2's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by TBarrow:
<HR></BLOCKQUOTE>
You are correct, bridges do freeze first but it's still impossible from even a bridge to to get ice on it if the actual temp hasn't reached the freezing point of 32F.
Old 11-09-2003, 02:19 AM
GOT DIRT? GOT DIRT? is offline
GOT DIRT? is off the scale
I just went out and at 36 it said the same thing. I think this is a cool feature sometimes we do not pay attention to conditions that may be hazardous
Old 11-09-2003, 02:27 AM
The manufacturers are always going to lean to the conservative side. I have an open top street rod and you can be going and pass an area that is 4-5 degrees cooler because of it being open to a cross wind.
Old 11-09-2003, 02:49 AM
MRH22U MRH22U is offline
MRH22U is off the scale
It's really to make you aware that the temperature is changing so you aren't caught offguard. This is particularlly important in elevation changes (mountainous terain). The european makers have had temperature alarms for years.
Old 11-10-2003, 12:31 PM
TJ TJ is offline
TJ is off the scale
That's not bad...I've gotten "Ice Possible" on the DIC on mild winter days at 52 degrees. After a call to tech support, dealer gave me a bunch of mumbo jumbo about "that's how it's supposed to work". So, if the manufacturer is leaning towards the conservative here, I'd say that is quite a lean, rivals the Leaning Tower of Pisa. But then again, maybe it's just that the H2 is the 8th Wonder of the World
Seriously though, if you notice, the temperature indicator on the rear view mirror is always off, mine by as much as 7 to 8 degrees. So maybe that's the reason for your getting "ice" at 37 degrees?
Old 11-10-2003, 12:37 PM
Zing's Avatar
Zing Zing is offline
Zing is off the scale
I get the same thing. Reason is that the temperature may have went below 32 degrees overnight. Even though it may now be 37 degrees it's telling us to be careful.
I think this more confusing than it is helpful, but that's the reason nonetheless.
H2 '04 Black
Old 11-10-2003, 04:17 PM
Orbital H2's Avatar
Orbital H2 is off the scale
Look at your thermal dynamics books guys...
when you are geting close to the freezing point, and you have some humitidy in the air and you have some breeze, and the barometric pressure is dropping, you get the heat transfer due to evaporative cooling and adiobatic expansion of gas, both of those can cause ice to form when the air temperature is above freezing. you also have the effect of the land mass radiating heat while the bridge does not have the thermal capacity to keep the ice from forming. Now if you want to check it out, I would suggets that you get a pyrometer that reads accurately a 0 deg C, an accurate charting barometer and charting thermometer. measure the temp over time on land simultaneously with measureing the temp of the bridge. You should be able to prove the above hypothesis.
H2 Black Lux, Air Suspension, AEM Intake, soon to be blacked out...
Black 02 Fatboy
300ZX TT 500Hp, 10.5Sec completely Blacked out, Wolfe Sport 600 Turbo, Billet Aluminum FlyWheel, Carbon Claw RPS Turbo Clutch, Dual Pop Intake, HKS Intercoolers/Exhaust
Old 11-10-2003, 04:23 PM
HummMe
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Orbital H2:
Black 02 Fatboy
300ZX TT 500Hp, 10.5Sec completely Blacked out, Wolfe Sport 600 Turbo, Billet Aluminum FlyWheel, Carbon Claw RPS Turbo Clutch, Dual Pop Intake, HKS Intercoolers/Exhaust<HR></BLOCKQUOTE>
Yeah--what he said.
Old 11-10-2003, 04:27 PM
NJ H2's Avatar
Black 02 Fatboy
WOW!! OK I will be trying this experiment today and will post my findings as soon as I come up with some hard facts!! Now if I could just remember where I put my slide-rule and compass
Old 11-10-2003, 04:38 PM
Orbital H2's Avatar
Sorry, I was cursed with that engineering gene at birth
Normal people ... believe that if it ain't broke, don't fix it.
Engineers believe that if it ain't broke, it doesn't have enough features yet."
Black 02 Fatboy
[This message was edited by Orbital H2 on 11-10-03 at 10:47 AM.]
Old 11-10-2003, 05:17 PM
maybe some day... maybe some day... is offline
maybe some day... is off the scale
When this came up a few years ago on another car forum the explanation was that ice can begin forming at 38 degrees fahrenheit. I forget the scientific mumbo jumbo that went along with it...
