Old 06-08-2004, 06:07 PM
JamesT's Avatar
JamesT JamesT is offline
Hello All,
I had this installed yesterday and it made a differance on mine. I especially noticed that the "sluggish" start I ofetn got when I hit the gas was gone. I helps with keeping the rear end in line as well.
http://www.edelbrock.com/tech/index.html
People Who Annoy Me...NAGGERS
JamesT's Avatar
Hello All,
JamesT's Avatar
Hello All,
Old 06-08-2004, 06:28 PM
Ok... are we supposed to guess which Edelbrock part you put on? Shocks, headers, nitrous system?
Can you give us a hint?
Old 06-08-2004, 06:40 PM
Can you give us a hint? <HR></BLOCKQUOTE>I think I read on that page that you have to email Edelbrock with technical questions like that.
Old 06-08-2004, 06:42 PM
JamesT's Avatar
Oppps! Description: Panhard Rod;
Part No: 5262 Installation Instructions
Warranty
Features
Tubular Design Eliminates Flex; Common w/Stock OE
Fluted; Greaseable; Graphite/Polyurethane Bushings
For More Precise Axle Retention
Increased Cornering Control
Allows Precise Alignment of Rear Axle
For Proper Tire/Fender Well Clearance
Adjustments Can Be Made w/o Removing The Panhard
Durable Jet Black Powder Coated Finish
Old 06-09-2004, 03:22 AM
James, what does this mean: "Vehicle must be supported with vehicle's normal weight on rear axle"? That is in the instructions. It does not make sense if the truck is jacked. Help.
Old 06-09-2004, 10:13 AM
Klaus's Avatar
Klaus Klaus is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by KenP:
James, what does this mean: "Vehicle must be supported with vehicle's normal weight on rear axle"? That is in the instructions. It does not make sense if the truck is jacked. Help. <HR></BLOCKQUOTE>
Wouldn't that mean that they want it on a "drive on" lift instead of jacks?
Old 06-09-2004, 11:20 AM
JamesT's Avatar
I do not know. I didnt install it as I am a pea brain when it comes to this type of stuff.
Old 06-09-2004, 12:30 PM
Thanks Klaus. That is about what I was thinking, but that could have been worded better by them.
