01-07-2006, 12:24 PM
can someone tell me what the aie suspension does and the advantage of it, i have a Yukon presentley that tas this and it keeps the vehicle level when a heavy load or trailer is attached , this is a very nice feature but i noticed that it is only available on the Adventure Hummer, can you get it on the luxury model also and what is the advantage?
thanks
ed
thanks
ed
01-07-2006, 12:35 PM
Some don't like it because it's another option to break. If you didn't get it on yours don't feel your at a disadvantage. I don't think many use it while 4 wheeling. Towing is the only nice thing to use it on. And I forget to turn it on while towing. So to me it's just another gadget. What really makes the H2 is the mechanical features.
01-07-2006, 12:49 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by It's a Dry Heat:
And I forget to turn it on while towing. </div></BLOCKQUOTE>
Say what?  You cannot turn it off!
01-07-2006, 01:31 PM
Yes, I usually forget!
01-07-2006, 02:01 PM
Bucks, this is from the 2003 Owner's Manual:
Electronically Controlled Air
Suspension System (If Equipped)
The electronically controlled air suspension keeps the
rear of your vehicle level as you load and unload it.
The system includes a compressor, two height sensors
and two air springs supporting the rear axle.
The engine must be running for the system to
operate and level the vehicle after loading or unloading.
The system will suspend leveling if any of the doors
or the liftgate are open. Once the doors are closed,
system leveling will continue. The system can lower
the vehicle to the standard ride height with the engine
running and for up to 30 minutes after the ignition has
been turned off.
You may hear the compressor running when you load
your vehicle, and periodically as the system adjusts the
vehicle to the standard ride height.
Load leveling will not function normally with the
inflator hose attached to the inflator outlet. Remove
the inflator hose from the outlet when it is not in use.
Overload and Overheat Protection
Overload protection is designed to protect the air
suspension system and is an indication to the driver
that the vehicle is overloaded.
If the rear suspension remains at a low height, the rear
axle load has exceeded GAWR (Gross Axle Weight
Rating). When the overload protection mode is
activated, the compressor operates for about 30 seconds
to one minute without raising the vehicle depending on
the amount of overload. This will continue each time the
ignition is turned on until the rear axle load is reduced
below GAWR. See “GAWR” in the Index.
If the system overheats, it will shut down and stop all
leveling functions until the system cools down. During
this time the SERVICE AIR SUSPENSION message
will appear in the DIC. See “Driver Information Center”
in the Index for more information.
Selectable Extended Rear Ride
Height (If Equipped)
This feature comes as part of the electronically
controlled air suspension system.
The selectable rear ride height allows you to raise the
rear of the vehicle approximately 2 inches (5 cm) over
the normal ride height. This can be helpful when driving
off-road where you may need more ground clearance to
clear an obstacle.
The button that controls this
feature is located on the
instrument panel to the right
of the steering wheel.
To use this feature, ensure that the following conditions
are met:
Be sure all the doors are fully closed. The suspension
will not raise or lower if a door is open.
Be sure the vehicle speed is less than 35 mph
(56 km/h). The system will not activate otherwise.
Press the height control button to raise the rear of
the vehicle.
A light in the button will begin to flash as the rear of the
vehicle rises. Once the extended height has been reached
(this may take up to a minute), the warning light will
stop flashing and will stay lit while the vehicle is at the
extended height.
To lower the vehicle to the normal ride height press the
button again. The light in the button will flash as the
suspension lowers. When the light in the button stops
flashing and goes out, the suspension has reached the
normal ride height.
This feature will lower the vehicle to the normal height
if vehicle speed exceeds 20 mph (32 km/h).
You may also want to use this feature when ascending,
descending or cresting a steep hill as this can help
prevent the rear bumper from dragging on the base
of the hill or prevent the vehicle from grounding out
(high centering) on the crest of the hill.
Do not use this feature when towing a trailer.
01-07-2006, 02:41 PM
Some don't like it because it's another option to break. If you didn't get it on yours don't feel your at a disadvantage. I don't think many use it while 4 wheeling. Towing is the only nice thing to use it on. And I forget to turn it on while towing. So to me it's just another gadget. What really makes the H2 is the mechanical features. </div></BLOCKQUOTE>
Ummmmmmmmmmm..IMHO yuou whould ignore this post. LOL The air suspension is a great option. The ONLY drawback would be that, yes, it IS another feature and therefore several more potentially broken pieces. The ADVANTAGES are outstanding. The load leveling ability is great. Not having your nose pointed to the sky when hauling a heavy trailer is wonderful. An extra little bit of clearance when off-roading (NOT trailering) is gained by pushing the button and raising the rear of the vehicle a couple of inches. The on-board compressor is another outstanding feature - not having to carry another piece of equipment for airing back up is, to me, a useful advantage.
I don't mean to be rude, but DryHeat doesn't seem to understand the system or is not using it properly and, well, NO system is a plus if you don't use it properly!! I wouldn't buy an H2 without it, but that's just my 2 cents.
Sean
01-07-2006, 03:43 PM
I had an 03 and the bags blew out. Your tires are up in your wheelwells when this happens and you have to wedge something in there so you can drive out. The option was nice for offroading for extra clearance and I used it often.
The 05 I purchased without it and did notice a difference in ride quality and missed if off road. I did not miss the fealing of wondering when/ if the bags would blow out aggain.
I have wheeled with many that have the air susp. and onl one has had issues other than me.
01-07-2006, 04:40 PM
It is great for ride quality, towing, airing up tires (I use it for my mtn bike). The extra 2 inches help way more than people give it credit for when off roading. I'm with bondage. Iwouldn't get one without it.
