Old 05-28-2004, 06:21 PM
It\'s a Dry Heat's Avatar
Might be Cepek wheels on an H1. Bead locker wheel might have saved this one.
Old 06-18-2004, 02:21 AM
Riding around the parking lots up there in Illinois doesn't count as offroading now, so no pavement pics.
Old 06-01-2004, 03:41 PM
DURAMAX TIM is off the scale
For my mud tires I have a set of MT classic w/ 12.5/35-16.5 General grabber MT.
I tried a few sets of steel wheels and they all hit the front calipers.
Some 16.5 aluminum wheels hit them too.
It depends on where the bead mounting area is spaced on the wheel.
I see some good prices on GY MTR in 12.5/37-16.5, may have to try them next time.
98 ZR-2 Blazer
Ex H2&3 owner
Old 05-29-2004, 03:11 AM
And crackers are good?
Going through a tight trail like this one on two wheels. two wheels on the ground and two wheels on the wall(or what ever might become the wall. This is the way Hummers get through narrow,(or jeep) trails. You can see picture below, Hummer needs bead lockers. Thank you for your comments. No cheese please.
Old 05-29-2004, 03:06 AM
Will these H1 wheels fit an H2? Mainly off-set, lug hole pattern, spacing and rubbing. I might be leaning stock tire size radical tires(JPs, MTRs. It looks like $799 each is the only one. Is that why beadlocker wheels arn't a hot item? cost!!
Old 05-29-2004, 12:19 AM
Hummerpilot Hummerpilot is offline
Hummerpilot is off the scale
Cheese
Old 06-17-2004, 10:47 PM
m998uparmour m998uparmour is offline
m998uparmour is off the scale
Someone who knew how to drive would have saved this one.
Old 06-18-2004, 03:07 AM
Beastmaster's Avatar
Beastmaster is off the scale
The picture shown is from Manny Macmillan and his Plum H1 Open Top.
The Wheels in question are Eagle 589 alloys in 16.5x12. I used to run the exact same rims on my H1 before AM General did a warranty flag on my truck while I was running them. I ended up selling them to Manny because he ran the exact same rims.
Yes, beadlocks would have helped.
And Manny knows how to drive. Look at some of his past runs here:
http://pubpages.unh.edu/~ejm/
M101A2 Trailer
