Old 02-28-2006, 05:48 PM
ok, so i got the new jc whitney catalog and i noticed this do-hickey called an oil change pump, it is a pump attached to a tank and u just syphon the oil out of where u put the dip stick and than add clean oil, of course u would still have to change the filter but what do u reckon about this?
Old 03-01-2006, 12:24 AM
Trinity Trinity is offline
Trinity is off the scale
I changed my oil for the first time today and all I have to say is make sure that you budget some time. You have to remove both skid plates to drain the oil. The placement of the oil filter is probably the dumbest location that I have ever seen, not to mention I think that the Incredible Hulk screwed mine on at the factory!
Old 02-28-2006, 08:15 PM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
I had a drain valve on my Harley to make that simple oil change a 'No-Brainer'... problem is, somehow, the valve got opened when I was on a dirt road and I was stuck.
My worry would be that the valve (like the one on my HD) could get opened by accident and you dump out all that important fluid on the ground and then you are stuck!
Take a wrench to the plug... Like Phil states... cant get much easier than that!!
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 02-28-2006, 06:39 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MONSTERMATT:
it is a pump attached to a tank and u just syphon the oil out of where u put the dip stick </div></BLOCKQUOTE>Don't be asking about your sexual devices on this family forum
Old 03-01-2006, 12:59 AM
Dug Dug is offline
Dug is off the scale
You must have more skid plates than i do??
Old 03-01-2006, 02:32 AM
i figured it was a stupid thing, just wanted clarification, and for those of you who like to off road, wouldnt u be worried the valve would come open on the trail?
Old 02-28-2006, 07:47 PM
saleen779 saleen779 is offline
saleen779 is off the scale
moss sells a valve that you can replace your drain plug with. when you want to drain the oil you just turn the valve by hand. can't get much more easier than that.
H2 for life!
