02-25-2006, 09:59 PM
Or is just an open diff w/ the traction contol only to control wheelspin?
I did seach, found nothing but stuff on adding a locker.
TIA.
02-26-2006, 02:30 AM
oops , i thought there was something in the front diff. that controled wheel spin and helped traction?? I think i'll check the level in it . Curious what the heck is vibrating.
02-27-2006, 05:05 PM
OK I'll "practice" today, great excuse to try those hills again after work!
02-27-2006, 04:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by instructor:
If you guys are looking to get rid of the torque limiting (engine holding 2000 rpm), pull the tranny into first gear. Like Phil said, if TC2 isn't working for you and you need more wheel spin, ride the brake enough to light the tail lights up, and it will override the TC system. </div></BLOCKQUOTE>
So if you are in 4Lo there is a "torque liniting" feature that wont let you go over 2000 RPM? That is why it feels like I'm hitting a rev limiter or something...Thanks for the info, I didn't know we had that. And to override this, just shift it down to 1st gear...
Let me get this straight. If I want to float through some mud I have to keep it in 1st while hitting the gas and tapping the breaks to override the TCS and Torque Limiting. Jeez, why not just have a button!
02-27-2006, 01:45 PM
I wheel Hummers for a living...
02-27-2006, 06:05 AM
Alec has a nice video that shows how to turn off TC2 really quickly.
02-25-2006, 11:41 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dug:
alan., i wasnt sure if the locker mechanism is causing the vibration and needed some jizum to lube it up. </div></BLOCKQUOTE>
LMAO!
We dont have lockers in the front. Onlt in the rear.
Try KY for lube! jizum's preferable for facials, etc. IMO!
02-27-2006, 02:19 AM
Alan 06, I think it would be great to turn it off.[/quote]
If the front is locked (after market eaton or arb air locker) and the rear axle is locked its not able work , you could run with only the front locked
TCS would work in back ??, or only the back axle locked then would the TCS work only in the front with the back locked . If you say it brakes one tire when you gas it in the mud its fighting the eng. I dont want a power robbing TCS coming on .
02-25-2006, 10:38 PM
If it is an open diff, then you should not add posi additive.
02-26-2006, 09:31 PM
PhilD , I am putting Eaton in the front . No need for taction control ?? they take out ttc.
02-27-2006, 12:27 AM
"If you know how to deactivate TCS/TC2 I'd be interested in knowing." quote:
Yes thats what I thought, I will see how they are doing it.
TCS/TC2 won't kick in if you locked front and rear, at least I've never seen it done so and can't think why it would, but it is still there. There are plenty of times when I'm in 4Hi that I'd like to flick a switch and turn it off though. quote:
OK I dont think I want it at all no (TCS) thanks for telling me.
02-27-2006, 05:23 PM
You don't want to just tap the brakes, you want to ride the brake pedal (enough to turn the brake lights) on. It takes a little practice to do it smoothly with your left foot, but not much. Kicking into first also works, I rarely have to do both, just pick the right one for the terrain.
It happens in 4Hi too, TCS takes over and controls throttle response when a wheel is spinning. I often will be in 4Hi going through loose sand, with my foot to the floor and barely moving. That's whaen it is time to "trick" the system. </div></BLOCKQUOTE>
Exactly. I just use first for the most part, just because its easier to pull the shifter back than it is to ride the brake (unless you are a blue hair). Alan, you would know if you were bouncing off the rev limiter, 6 grand, motor wound tight...
02-25-2006, 10:27 PM
Phil, do you know if the front diff. needs any supplemental additive in it. Like some rears have a posi additive. I'm asking because my front end is making a harsh noise/chatter . I have looked at the ujoints in the driveshaft and looked at the front axle shafts, they feel tight. The noise/chatter/vibration is only when its criusing and not under strain. When its under power or turning the noise goes away. Maybe a wheel bearing?? or something, just looking for someones idea before i tear in to it. Thanks doug
02-26-2006, 06:27 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Alan06SUT:
We dont have lockers in the front (<span class="ev_code_RED">from the factory</span>). </div></BLOCKQUOTE>Speak for yourself  </div></BLOCKQUOTE>
Sorry  Fixed it!
02-27-2006, 12:59 AM
on muddy hill climbs that darn TCS kicks in and doesnt let you spin enough, I have tried w/ the TC2, and same thing. Does it do something to the accelerator or do the brakes just make it feel like the motor is bogging down?
Also today I was in some thick, nasty mud and needed some floatation to get through parts of it and even when I slammed the gas hard, it still only spun a little.
I like the TCS when it is fairly dry, but when it gets a little slippery, I think it would be great to turn it off.
TIA.
02-25-2006, 10:45 PM
02-26-2006, 02:43 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">i thought there was something in the front diff. that controled wheel spin and helped traction?? </div></BLOCKQUOTE>
The t/c isnt in the diff, it uses a Bosch system that senses wheel spin and applies the brake to the spining wheel.
02-27-2006, 04:44 PM
Nice I didn't think of doning that (tapping brakes to override). Hey Instructor...Why dont they just have a button to turn it off?
Hybrid Mode
