Old 01-15-2004, 03:04 PM
Bad Dawg Bad Dawg is offline
Bad Dawg is off the scale
Has anyone had their key stick in the ignition? Both my key and my wife's keys have gotten stuck. We have tried turning it back and forth, starting the engine again, etc, etc. They eventually came out for some reason. The last time I tapped on the steering column and it seemed to release it. I realize it's cold out but I don't think that is it.
You can never have enough horsepower! Yellow LUX, Airforce intake, stainless headers and exhaust, Gobi rack and ladder, roof mounted off road lights, full wrap brush guard, rear light guards, outside tire carrier, Rancho 4" suspension lift, Ultra "EN4CER" 17x9 wheels, Goodyear 37/12.50R17 MT/R tires, removed side-step bars, 9.5ti warn multi-mount winch.
Used to be an H2 owner
Old 01-15-2004, 10:52 PM
I had the same problem, but it seems to have fixed itself. But it is on my mind now so it will definitely get stuck again.
Black Lingenfelter Lux
Old 01-16-2004, 01:52 PM
So far it's just been my key and not the shifter. What's a btsi switch? I need to take it in to the dealer for the oil change coming up. I'll mention it to them then.
Old 01-16-2004, 03:51 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
seen this problem a few times it's likely your btsi switch on the shifter assembly, can't get just the switch have to replace shifter as an assembly. also check for broken wires to the btsi switch (4 wire connector on right side of shifter assembly).
1998 Chev Z71
2007 Chev Trailblazer SS
Old 02-16-2004, 12:32 PM
Dealer said it was the switch on the shifter. There has been a recall of some sort on them. My guess is that they only fix it if someone has a problem. The parts are in, so I guess I will get back in to have it fixed. Got a new sunroof seal too. The trim that covers up the headliner edge around the sunroof wasn't going over far enough. A raw edge of the headliner was exposed. Sure hope the new trim covers it.
Old 01-15-2004, 05:28 PM
prplprowlr's Avatar
prplprowlr prplprowlr is offline
prplprowlr is off the scale
Yes, mine had done it for a week 2 weeks ago and my shifter was sticking as well on the days it was below freezing, now the weather has gotten close to normal I have not had any problems? What I had to do was turn my key forward then back to get it to release from the ignition.
2006 H2 Desert Sand SUT (blacked out)
2007 H2 Slate Blue Metallic SUV (chromed out)
Old 01-16-2004, 01:42 AM
Detonate Detonate is offline
Detonate is off the scale
Happened on my 97 GMC Sierra, weiredest thing. Spent 5 hours in a Diamond Shamrock Parking lot with a Locksmith. Finally we just drilled the lock, and replaced the ignition.
North Texas Hummer Team Member
2003 Red H2 equipped with Tough Country Heavy Duty Armor Series Front End with Winch, Rear Bumper, Brush Guard, and Roof Rack.
</center><hr>
