Old 02-28-2005, 11:36 PM
HummerH2 HummerH2 is offline
HummerH2 is off the scale
anyone else have this problem mine is off to the left by a few centimeters also i can move the wheel alot before the wheels move
Old 03-01-2005, 12:53 AM
Yes, this has been discussed before. The steering shaft comes out tilted toward the driver's side door. Go check your other GM trucks and I bet they do the same. Both my Tahoes had it and so did a car or two.
Someone here must have and explaination as to why it is like that.
Old 02-28-2005, 11:38 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummerH2:
anyone else have this problem mine is off to the left by a few centimeters also i can move the wheel alot before the wheels move </div></BLOCKQUOTE>
Did you have a FE Alignment done recently?
been off-roading or hit any curbs hard?
or
Is this a new rig and it has always been like this? If this is true it may be your idler/ pitman arm going bad or something along those lines.
Old 02-28-2005, 11:42 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Mine has been off to the left slightly since new but doesn't pull one way or the other so never worried about it. It's alignment or bad steering part problem. I would have it checked because of the slop in the steering you mentioned.
Jonahs
Old 03-01-2005, 12:57 AM
Here is a link:
http://elcova.com/groupee/forums/a/t...861#5726048861
There's some talk of it within this thread:
http://elcova.com/groupee/forums/a/t...723#9116095723
