Old 04-04-2003, 01:47 PM
H2_GUY H2_GUY is offline
H2_GUY is off the scale
Is the hood fiberglass or plastic look like it’s plastic ???
-----Mother of all SUVz-----
Old 04-04-2003, 01:53 PM
Colo. H2 Colo. H2 is offline
Colo. H2 is off the scale
That is hole not whole. I need more sleep!
Red 03 Lux. & Adv.
Old 04-04-2003, 01:51 PM
Under the hood (where the hood prop rod would go if I had one)I can see the fiberglass strands near the edge of the whole.I vote fiberglass.
Red 03 Lux. & Adv.
Old 04-04-2003, 07:35 PM
Hummer Man is off the scale
Whoops left out that rubber and aluminum make up other big percentages of the Hummer H2 - sorry!
Old 04-04-2003, 01:58 PM
It is a GLASS FILLED - POLY PROPALYNE. Made by
GENERAL ELECTRIC PLASTICS.
Same stuff as all the body parts of the SATURN CARS ARE MADE OFF. Only it is 36% Thicker Because of off road use and size / span.
Old 04-04-2003, 07:33 PM
PLASTIC is a broad term ! Technically and I don't want to bore you guys but most of whats in "FIBERGLASS" is plastic. And of course glass fibers are in everything from insulation to concrete for added strength.
You say --- PLASTIC like it is somehow cheap!
4100 pounds of steel in the Hummer H2
1460 pounds of PLASTIC and the rest is other (WIRES, Buy OUT COMPONENTS Like the radio, Insulation, Cloth, Leather etc.)
FUN FACT: even with the hood this vehicle has less plastic as a percentage then any other passenger vehicle on the market.
Old 04-05-2003, 01:24 PM
SOFTTAILJC's Avatar
SOFTTAILJC SOFTTAILJC is offline
SOFTTAILJC is off the scale
in the manuel they call it composite...soft
Old 04-04-2003, 04:56 PM
POLY PROPALYNE <-- If I remember my chemistry correctly that’s plastic ....
