Old 01-17-2006, 03:24 PM
BlueTJCO's Avatar
BlueTJCO BlueTJCO is offline
I was reading this on another forum, it is regarding Alec's tie rod incident. This guy really knows what he is talking about....
"I am pretty sure that that video was taken on the Big Sluce on the Rubicon Trail. I've seen well built CJs and FJs with broken axles, broken chassis, steering boxes ripped out of the chassis, stripped gears, and even a transmission and transfer cases that split in half from the hammering!!
To get to that point on the trail that H2 would have gone through a LOT of abuse. I did the trail in a STOCK Range Rover, and it is a tough trip, so much so that a British magazine published a story about our trip when they heard bout it. (Land Rover World, April98) We bent tie rods many times on the trail. My guess is that it was already damaged from repeated blows. That's why one of the first things that truck owners do is to significantly upgrade their tie rods.
Taking any stock vehicle on that trail is insanity. (yes, Jeep does it, but with lots of spare parts, support vehicles, mechanics, and later in the year after it has been smoothed out from previous adventurers.
Also, even if I am wrong about the trail, the wildly spinning tire grabbed on the rock and put a LOT of pressure on that wheel. Letting a tire spin like that is a no-no for experienced off-roaders, and WILL lead to damage. The mark of a novice, (or an experienced off-roader with a split second of brain fade that we all get sometimes.) Abuse like that is like taking your econo box, revving it to 6000 rpm, and dumping the clutch over and over, then wondering why the trans, axle, or clutch failed.
Nope, that H2 was doing pretty good. It was just a bit of driver error. And yes, a heavy duty tie rod might have not broken. But, the tie rod and tie rod end is about the easiest thing to repair. Think of it as the fuse in the link, and if it is overbuilt, then instead of the tie rod you will break steering boxes, rip steering boxes out of the chassis, break stub axles, snap off steering arms, etc."
If memory serves me correct, we were at Bill Moore Lake in Colorado
You could get a ****ing subaru outback up there
this quote is the funniest:
"To get to that point on the trail that H2 would have gone through a LOT of abuse"
LMFAO for anyone who knows what I'm talking about. I love when people want to know so much more then they do.
"moonie"
Old 01-18-2006, 01:05 AM
I like the Rubicon story better </div></BLOCKQUOTE>
You've already run the Rubicon?
Where's the link? </div></BLOCKQUOTE>
A moderator deleted it because he was jealous </div></BLOCKQUOTE>
I believe it...
I haven't got the heart to tell you guys I ran it with my eyes closed in one day. Most guys take two days with both eyes wide open. And I caught the biggest Trout you've EVER SEEN!
Old 01-18-2006, 01:56 PM
I believe it...
I haven't got the heart to tell you guys I ran it with my eyes closed in one day. Most guys take two days with both eyes wide open. And I caught the biggest Trout you've EVER SEEN! </div></BLOCKQUOTE>
Tis True. I ran it backwards so that I could take action photos of her doing it.
Old 01-18-2006, 04:07 AM
I ran Rubicon after the TC failed. You fools thought I was still at the Gonzo. Hell no! I drove too damn far not to head on over and cruise through the rubi. Just like a Sunday drive, Baby.
I'll post pics soon.
Old 01-17-2006, 04:04 PM
I happen to know for a fact that the driver was indeed on Big Sluice on the Rubicon, broke the tie rod and kept wheeling. He had air suspension and manually adjusted it so that only 3 tires were on the ground. He was limping around to find a flat, easy spot to change the tie rod and ended up at Bill Moore Lake, only about 1000 miles. Upon finding the good area to change the tie rod, he realized he didn't have a spare and had to walk all the way back down to the little Jeep roads and get a ride with a Jeeper to town to get a replacement rod.
Old 01-17-2006, 03:33 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mooncricket:
</div></BLOCKQUOTE>
You can get an Outback up to the top of Bill Moore easily, but I certainly wouldn't take one on that boulder field shortcut where Alec's famous video was taken.
Old 01-17-2006, 07:03 PM
I've done that section of the Rubicon myself and it only claimed my side mirror.
Old 01-17-2006, 04:06 PM
I happen to know for a fact that the driver was indeed on Big Sluice on the Rubicon, broke the tie rod and kept wheeling. He had air suspension and manually adjusted it so that only 3 tires were on the ground. He was limping around to find a flat, easy spot to change the tie rod and ended up at Bill Moore Lake, only about 1000 miles. Upon finding the good area to change the tie rod, he realized he didn't have a spare and had to walk all the way back down to the little Jeep roads and get a ride with a Jeeper to town to get a replacement rod. </div></BLOCKQUOTE>
So the nimrod helped the hotrod fix the tierod.
Old 01-17-2006, 04:39 PM
That's pretty funny stuff right there.
Old 01-17-2006, 08:59 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
I'd go with it, that was quite an impressive yarn. Since the dip****s that keep bringing up "Killedit" haven't a clue about the conditions, and won't acknowledge their vehicles own weak points. Fawk 'em.
Old 01-17-2006, 09:47 PM
Where's the link?
BlueTJCO's Avatar
"moonie"
Old 01-17-2006, 08:31 PM
X2
I saved this link to my favorites and will post the story every repost of "killed it".
Old 01-17-2006, 04:09 PM
BlueTJCO's Avatar
I happen to know for a fact that the driver was indeed on Big Sluice on the Rubicon, broke the tie rod and kept wheeling. He had air suspension and manually adjusted it so that only 3 tires were on the ground. He was limping around to find a flat, easy spot to change the tie rod and ended up at Bill Moore Lake, only about 1000 miles. Upon finding the good area to change the tie rod, he realized he didn't have a spare and had to walk all the way back down to the little Jeep roads and get a ride with a Jeeper to town to get a replacement rod. There were plenty of H2 owners in the area, but he was indeed worried about another H2 having to negotiate the trail again, so he found a Jeeper to get him back up </div></BLOCKQUOTE> </div></BLOCKQUOTE>
"moonie"
