Old 10-18-2005, 08:26 PM
MrAgent007's Avatar
MrAgent007 MrAgent007 is offline
MrAgent007 is an unknown quantity at this point
Hello, I am looking to install a CB radio in my H1 wagon and looking for antenna mount options to my rear bumper. Any suggestions or pictures of mounts? If so, please send. Thanks! Alex
Old 01-03-2006, 11:21 PM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Two Washers welded at 90 degres to one another at the edges and your front window mount bolt works pretty good and costs about 50 cents.
Old 10-18-2005, 10:39 PM
Beastmaster's Avatar
Beastmaster is off the scale
Bumper mounts are somewhat of a pain. You need a long enough antenna to clear the body of the vehicle and still have enough antenna over it to transmit properly.
If you have a roof rack, you are better off mounting it up there. You have a good ground plane and many mounting options.
The other option is to do a glass mount. Radio Shack - 49 bucks.
M101A2 Trailer
Old 11-07-2005, 04:32 AM
HUMMERDOGG HUMMERDOGG is offline
HUMMERDOGG is an unknown quantity at this point
ckhagman-
I went to your website but am unable to access any of the pictures or write-ups after I click on the Modifications Pictures. Can you post pictures of the angle iron you used to support the body mounts of the tire carrier?
Thanks,
-HUMMERDOGG
Old 10-25-2005, 09:25 PM
MrAgent007's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ckhagman:
Philadelphia?
I you are ever in West Chester there is a place on 202 that sells CB products and he has the stainless steel spring and will probably have the mount also.
Chris </div></BLOCKQUOTE>
Old 10-25-2005, 10:13 AM
Joe Joe is offline
Joe is off the scale
There is a picture of my bumper mount install here:
http://homepage.mac.com/babiak1/Mods1.htm
I recently updated the install to a billet mount and heavy duty spring and sighly suggest if you bumper mount not to go with anything but a heavy duty setup, you'll end up for a drooping antenna in no time otherwise. I wish I could remember the vendor for my setup as it is really nice, best bet is to check around on the web.
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 10-26-2005, 08:39 PM
ckhagman ckhagman is offline
ckhagman is off the scale
Chadsford Electronics
1485 Wilmington Pike (Rt202)
If you take 202 south from west chester it is on your left after you pass the cavallo auto body. You will have to do a turn around at the wawa at the next light. It is very small. It is near the row of small shops.
Small world as I was just drove up 252 from Newtown square this morning.
What color is your truck.
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 10-27-2005, 04:08 AM
Joe-
On your website you make mention of having problems with the weld breaking on your slantback tire carrier. What brand was it?-it doesn't look like the Predator brand carrier? What happened?- just shoddy craftmanship???
Thanks,
-HUMMERDOGG
Old 10-25-2005, 09:26 PM
MrAgent007's Avatar
Philadelphia?
Hello Chris, What is the name of the place in West Chester? I live in Paoli. Thanks!
Old 10-27-2005, 01:18 PM
MrAgent007's Avatar
Thanks for your response. Yellow.
MrAgent007's Avatar
Old 11-03-2005, 10:51 PM
Well it is about time they billed you. But you still have a nicely priced tool box
HUMMERDOGG the predator one is really nice. I added angle iron on the body mounts which I am really happy with.
Old 11-03-2005, 11:23 AM
Joe Joe is offline
Hummerdogg.
The carrier was made by Unlimited Offroad. A company that I will only say you should do some serious background checking on before you buy anything from them.
The weld and design was just poor. In the end the post the tire mounted on carried all the weight because it was to high. The tire's weight never rested on the frame itself to distribute the weight.
I've seen the Predator one, Chris Hagman has one and its a solid and much nicer product.
I replaced my tire carrier for the RhinoLift tire carrier that mounts on the bumper. I can only say it one of the nicest products I've ever seen. Solid, functional and just easy as hell to use. And trust me, over the 3-4 months since I got it I've had ample opportunity to use it. oh the joy of cutting tires.
I've been real happy with just mounting a heavy duty "plastic" storage box up where the tire was. The extra storage is great for holding all those tools and extraction gear that I use to have all over the place.
p.s. Chris, they finally billed me for the rhino
2001 H1 Opentop
2003 H2
Homepage:
Old 11-07-2005, 11:26 AM
I fixed it.
Sorry about that. If you need a larger picture let me know.
http://www.penta-nut.com/mods.htm
Old 10-25-2005, 11:08 AM
Philadelphia?
Chris
