Old 09-27-2003, 08:53 PM
barbender barbender is offline
barbender is off the scale
I've owned my H2 1 month and just noticed when it rains hard or I wash my truck water is running down inside the right front roof support trickling out of the grab handle bolt cover. I discovered the passenger carpet was soaked. Anybody had this problem? Could it be a faulty seal around the antenna?
Old 10-04-2003, 10:00 AM
Brad Brad is offline
Brad is off the scale
TBarrow,
Why do you say silicone will cause rust on a painted surface?
Old 09-27-2003, 11:01 PM
Here it is.
http://www.elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=534603419 3&r=4556017593#4556017593
It should get you started.
He ain't heavy.....
He's ma HUMMER baby!
03 NUDE Pewter Lux H2
03 Dressed Range Rover
Old 09-27-2003, 10:01 PM
Kevin B Kevin B is offline
Kevin B is off the scale
You might want to check the running light on the front corner of the roof, it has a built in jacuzzi
Old 10-04-2003, 09:58 AM
CMB,
A few months ago I took it in for some work and had to fight them like dogs to get a vehicle to drive. Luckily I knew a manager and he took care of me. My point to them was I am buying a 55k dollar truck and can't even get a loaner! They said Sonic had taken all of those privi's away. My wife drives a Lexus and it doesn't matter what we take it in for they always give us a car to drive. We can even take it in anytime just to have it washed.
I told them that there competition was taken care of customers alot better than they were.
Besides the loaner problem they have been OK, typical dealer justifacations on problems.
Old 10-04-2003, 10:07 AM
Dan Dan is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by TBarrow:
You don't want silicone against a painted surface as it causes corrosion/rust.
...<HR></BLOCKQUOTE>
That's a new one to me ...
Then how about Latex Adhesive caulk?
- Dan
SUT on order 12/02. 10 months down, 8 to go!
Old 10-08-2003, 09:24 PM
Thanks cmb.
I'LL look forward to hearing from you.
Old 10-04-2003, 10:04 AM
cmb,
Where do you live?
I am getting ready to build a house in Brentwood.
As far as recommending someone at the dealership, There was one guy there I liked and he left. There always seems to be alot of turnover at dealerships.
Old 09-28-2003, 09:05 PM
Thanks for the suggestions. I'll visit the dealer tomorrow. This seems like a very weird way of getting water off the roof !@#$%
Old 10-12-2003, 09:42 PM
TBarrow TBarrow is offline
TBarrow is off the scale
Mine is also in the shop coming Monday morning as I to sprung a leak at both grab bars.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, 2-7" screens in headrests with DVD player and TV Tuner.
Old 10-14-2003, 12:03 AM
Ok mine is fixed. The center lights have a sponge type gasket that had colapsed. they removed the lights and put a urethane seal between them and the truck. There is a tray assembly below the lights that ends about 2.5 - 3 inches from the end and if the lights leak it comes in at the handles. The drivers floor board was damp so the jute was also replaced 15 minutes while I waited for all. I was also experiencing a vibration at higher speeds and it is also now gone.
Old 09-29-2003, 12:44 AM
Texas Red's Avatar
Texas Red is off the scale
I think the clogged drain tube is only an issue with a sunroof installation, but others have had problems with the front roof lights not being sealed well.
Jim
Red H2
Jim
2008 H3 Graphite Lux
Old 10-03-2003, 10:55 AM
Dan Dan is offline
Is it possible to pop the light out, put in a bead of clear silicone adhesive caulk, and stick the light back in?
I would think that'd seal it up nice, and the adhesive caulk would hold it in good. Adhesive caulk having better holding power than the regular stuff.
Just a thought...
- Dan
Old 10-04-2003, 11:13 PM
Check with your windshield companies as I was told this years ago. They only use a urethane sealant where it comes in contact with the metal. I have never asked why just been told numerous times even last month when my H2 windshield was replaced.
Old 10-12-2003, 08:38 PM
Hard rain last night. My Passenger side carpet is soaked! I pulled up the trim piece by the door and an inch of water sitting there. Two beach towels worth! Back to the dealer tomorrow.
Old 10-03-2003, 10:21 AM
I haven't taken mine through a commercial car wash and now I won't in the future. I pay my kids to wash it.
Old 09-29-2003, 07:32 PM
I visited the Dealer today. First Class service (Orlando Hummer) They installed a new corner roof light while I waited. They seemed sure that was it. I'll see what happens, it looks like rain.
Old 10-01-2003, 07:53 AM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
Brad,
How good has Crest Hummer been to you? I just got a 04 and want to know if I should be prepared. Anyone there you would recommend or not recommend? Thanks for the help.
CB
Craig
04 Pewter H2- Lux,nav, air suspension
Old 09-28-2003, 01:36 AM
Clogged drainage hoses are the culprit. Easy for the dealer to fix just make sure they clean your carpeting.
Old 09-27-2003, 10:46 PM
Circuitguy
Yup! Hell check all the running lights on the front of the roof! The lights in the center can get bumped off in a car wash then you will have a leak. Welcome to the "having fun at the dealer club!" BIG-C
White 03-H2-LUX
</a>
