12-10-2003, 09:15 PM
Has anyone done a dual-battery setup yet. If so, where did you locate the new battery.
I've got several things backed up that I have been needing to do and have parts everywhere. I plan on adding the Pioneer adapter setup for adding my MP3 player and XM satellite, I have a 1200 watt inverter I am adding, I have a hands free kit for my Motorola phone, I have a portable DVD/VHS setup that I want to make easier to plug up, I am setting up so my notebook will read from the Garmin GPS, installing Cibie Tangos in the DRL location, etc.
I have already run the battery down as the cigarette lighter plugs are always hot and are not protected against the battery run down feature like the lights are. So, I think I am going to add another solenoid that's switched like the winch setup that will power on/off all of the lighter plugs (except for maybe 1 or 2), other hardwired electronics and the power inverter.
I think more available amps would be logical with the addition of the new electronics, especially since some of the stuff is left on after the ignition is off.
Thoughts?
12-13-2003, 04:33 AM
To the left of the compressor, there is plenty of room for an additional battery. It will tuck nicely behind the bumper and leave you with about 4-5 inches between....Currently building a weatherproof steel box to hold a pair of westco 6 volts. These 2 batteries combined are about the size of an Optima, maybe a little larger..*note* Always be cautious about using an Optima as your main.
12-10-2003, 11:54 PM
I have the optima yellow in my Sub.. Have left lights front lights on along with the red and blues for along time at Crime/accident scenes.. Left interior light on for 2 days and never killed the battery.... I buy the biggest damn battery that will fit .. Attached is pix with lights.
Consider the OPtima before yo go the dual battery option.
Mike
12-10-2003, 10:40 PM
i have often thought of adding a second battery when I mount lights on the sides of my rack. when you take a good look, it is hard to find a good place to put one in the front. I was actually considering switching to one of those 'gel' batteries.. amperes higher. could solve your prob...
unaslob
12-10-2003, 11:48 PM
Costco sells Optima red top batteries for about $100.
I plan to buy one soon for the H2. Delco batteries have a bad habit of leaking acid. IIRC, someone on this forum had that problem.
Klaus
12-10-2003, 11:42 PM
paragon, I had thought about that as well, but I think it would be a big pain in the ass mounting it in the rear... plus I would be fearful of wacking it on something. I am probably going with the gel... but they can be pricy..
unaslob
12-13-2003, 02:21 AM
It's dark now but I will take some and post in the morning.
12-13-2003, 02:07 AM
I have installed two of the optima red tops from costco, I used the Painless Wiring solenoid to manage charging/isolation. I had to remove the factory tray and fab a new one. In addition the batteries had to be mounted on their sides.
12-13-2003, 02:11 AM
rogueH2 have any pics???
unaslob
12-10-2003, 11:06 PM
I even thought of maybe having a protected mount made to install one somewhere under the rear near the stock compressor. It's about the only place I could think of that has room and I thought about using one of those gel racing batteries.
Thoughts?
12-13-2003, 03:46 PM
Pics
Hybrid Mode
