Old 06-18-2005, 12:49 AM
glennc glennc is offline
glennc is off the scale
Does K&N make a stock replacement air filter for the H2?
\'05 H2 SUV, LUX, Stealth Gray
Old 06-19-2005, 01:58 PM
Thanks everyone. You helped put my mind at rest.
Old 06-27-2005, 03:28 PM
I installed my Airaid Jr. kit. Though not scientific, the vehicle does seem to pull a little harder with no real increase in noise from the air filter (which is what I wanted). I will see how MPG goes. Thanks again to all.
Old 07-12-2005, 12:07 AM
Status Update:
Continues to improve. Now up to 10.6. With the price of gas these days, that is great news!
Old 06-18-2005, 06:16 PM
Thanks again. Yes, I am actually leaning towards the Airaid Jr. kit at this time. Is it a quality brand/product???
Old 06-18-2005, 12:55 AM
If so, do you have the part number? The dealers I checked with do not show an actual part number. Strange. Is Airaid the only solution?
Old 06-24-2005, 06:21 PM
Klaus's Avatar
Klaus Klaus is offline
I believe the K&N type filters give very little, if any performance increase.
I run a supercharger and the factory filter works fine. Save your money.
Old 06-20-2005, 02:33 AM
I'm ordering the Airaid Jr. kit for all these reasons as listed in this (and other) discussion thread. I hope it fits and performs well while maintaning a reasonble sound level similiar to stock (since it uses the stock air box). Again, thank you all.
Old 06-18-2005, 12:58 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Have you tried
http://www.summitracing.com
http://www.autoanything.com
2003 Yellow H2 LUX (Sold)
Old 06-23-2005, 08:09 PM
therock therock is offline
therock is off the scale
When using an oiled air filter, after the initial install or servicing, run it for a week or so and hit some hi RPM's a couple of times and then clean your MAF elements. If an oil residue accumilates there it will have the MAF lie in a negative manner that effect mpg, shifting, idle and so on.
There is a GM TSB stating if the symptoms described above are found and traced to an after market oiled air filter, it is not to be covered under warranty.
My Truck
Old 06-18-2005, 01:05 AM
KACYK, thanks for the quick reply.
I can't seem to locate the part on either of the websites. Any thoughts?
Old 06-25-2005, 03:28 AM
kacyk's Avatar
Observations on a 5.3 Yukon with Airaid Junior and Airaid Throttle Body Spacer.
Last week I installed both units in the Yukon to be my "test" vehicle before doing anything on the H2. Prior to this I installed a K&N FIPK in my Tundra and found it to yield no noticeable increase in either MPG or performance.
1. Installed the Airaid Junior kit which consists of a new "high flow" MIT and Filter. Unlike the K&N FPIK, this retains the original air box so the sound is not obnoxious yet it does raise the decibels slightly at full throttle. I actually like the sound as it is reminiscent of a 1950’s muscle car. As for the power? I actually experienced a decline in power throughout the midrange. I can’t give any dyno figures but it feels more sluggish than with the OEM setup. Perhaps I expected too much? Not really as I had the same experience with the K&N FIPK. So why did I buy it? Well, I can return it for a full refund and there’s always that glimmer of hope that a different application might yield better results.
2. With the Airaid Junior in, I then installed the Airaid Throttle Body Spacer. Okay, now this made a DIFFERENCE! The throttle response was quicker, the sluggishness went away and highway passing is now a breeze, even with all seven of us in the truck! I’m not sure if all three mods work together of if just the throttle body spacer alone would yield the same results. But there is a definite difference. Any down side to the Airaid Throttle Body Spacer? Yes, an annoying high pitched screeching sound (same sound as faded brake pads on thin rotors) at 2000 RPM. This “screech” according to Airaid is “normal” on many applications. No amount of “perceived” power increase or quicker throttle response is worth the mind numbing sound. Since my Yukon cruises at 2000 rpm, I am returning everything! How unfortunate!
Old 07-01-2005, 07:06 PM
Status Update: Since I added the Airaid Jr. kit my computer is telling me that my MPG has improved from 9.8 to 10.4. This is really great news with the price of gasoline lately.
Old 06-21-2005, 01:42 PM
Mark Foch Mark Foch is offline
Mark Foch is off the scale
Do yourself a favor & stay with OE.
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Old 06-18-2005, 01:33 AM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by glennc:
Does K&N make a stock replacement air filter for the H2? </div></BLOCKQUOTE>At this time K&N offers only an Intake "Kit" for the H2. Airaid, Green (#2331), True Flow (#10220), & prbably some others offer drop-in upgraded filters.
Old 06-18-2005, 10:44 PM
sclui56 sclui56 is offline
sclui56 is off the scale
Thanks again. Yes, I am actually leaning towards the Airaid Jr. kit at this time. Is it a quality brand/product??? </div></BLOCKQUOTE>
Have been using that on a stock 05 for awhile, the only other engine-related mod is the MagnaFlow exhaust. I decided to put back the stock filter & tube couple days ago just for kicks, and I did notice the difference, nothing drastic, but there's a difference.
As far as the company goes, I had excellent customer service. I ordered mine from AJ USA, and the MIT I received had some very deep cuts on it (from box cutters or something probably), Airaid ended up sending out a brand new one overnight with all the fittings, etc.
Old 07-12-2005, 01:50 PM
SoonerBoarder's Avatar
SoonerBoarder SoonerBoarder is offline
SoonerBoarder is off the scale
K&N doesn't make one right now, but the company called Green Filters does. They are basically the same thing. It's a Green Filters part number 2331
Old 06-18-2005, 07:33 PM
Thanks again. Yes, I am actually leaning towards the Airaid Jr. kit at this time. Is it a quality brand/product??? </div></BLOCKQUOTE>AiRaid is an excellent company & offers a fine product. They are a little more aggressive than K&N when designing CAI's offering a more limited selection, but generally equal or slightly better performance numbers. You'll be satisfied with AiRaid's products.
Old 06-24-2005, 05:44 PM
Mr. I - Man's Avatar
Come on Focher! GM and Spicer sleep in the same bed. You don't think the tests are a wee bit biased??
