Old 06-12-2003, 05:16 PM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
Does anyone have the bulletin for repairing the Auto Volume Control on the Radio ???? I cannot locate it ...
Thanks,
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 06-12-2003, 11:29 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Further, anyone have instructions on removing and re-installing the center console?! <HR></BLOCKQUOTE>
Important
For easy access to center console and I/P removal, the front seats should be removed.
Loosen the locking hex screw that fastens shift lever to floor console shifter.
Loosen screws that hold front trim panel and remove from center console.
Remove hinged arm rest cover from center console.
Remove top panel from center console.
Remove storage bin screws and remove storage bin from center console.
Disconnect electrical connections to center console end cap and unscrew from center console
Remove screws holding center console to center console bracket.
Remove center console.
This is the proceedure from the service manual. Sounds like a lot of work.
Be sure and pull the fuse for the amp before disconecting the plug on the harness and leave removed until the harness is reconnected. I remember someone saying they blew the amp by not pulling the fuse for it first.
[This message was edited by Hummie2 on 06-12-03 at 06:49 PM.]
Old 03-17-2007, 06:11 AM
tower's Avatar
tower tower is offline
Default Re: Auto Volume Control on Radio
http://www.elcovaforums.com/forums/showthread.php?t=6623&highlight=center+console+rem oval
Old 06-12-2003, 10:51 PM
Hummie2's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Does anyone have the bulletin for repairing the Auto Volume Control on the Radio ???? I cannot locate it <HR></BLOCKQUOTE>
Click on the FAQ in the left sidebar, scroll down to item #14 under service bulletins and click on it. The service bulletins were posted by Klaus and Jason moved to the FAQ section.
Don
Thanks,
Michael
Pewter Hummer H2
Northern California
Michael
Pewter Hummer H2
Northern California
Old 06-12-2003, 06:16 PM
