Old 10-10-2005, 03:05 PM
leenigen's Avatar
leenigen leenigen is offline
leenigen is off the scale
Whos rplaced an axel seal and a pinion seal? They are cheap and it seams pretty easy (per repair manual) but is it really? Do I need special tools to remove them?
Old 10-11-2005, 04:52 PM
Beastmaster's Avatar
Beastmaster is off the scale
No. I had my diff out because I was pulling the Torsen out.
Leaving it in actually makes it easier.
M101A2 Trailer
Old 10-11-2005, 01:34 AM
By "axle seal" I'm to assume it's the output shaft seal.
If you are talking about that - that is really easy to remove....(you need a seal puller), and replace (you need a seal installer, or barring that, take a 3/4" shackle and use that as a seal installer). I've done a few with the shackle as the seal installer.
For the pinion - you'll need a seal puller, and you need at least something to help keep the seal in place as you drive it in. I've only done one of those - with the diff out when I did my Detroit build up.
-Steve
It is really easy for the pinion
M101A2 Trailer
Old 10-11-2005, 11:06 AM
leenigen's Avatar
Thanks, It seems easy enough and I don't think I'll have any problems. I guess I was just looking for a word of warning if it was too difficult.
I'm planning on leaving the dif in the truck while replacing the seals. Will that make things way more difficult?
leenigen's Avatar
Old 12-29-2005, 03:41 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
The seal will come out easier and cleaner without heat if you use the side yoke and smack it with a sledge hammer to pull the stub axle /side bearing/side seal out as an assembly.
Dave
Old 12-29-2005, 11:18 AM
leenigen's Avatar
Well I finally got around to changing those seals. The pinion seal went easy enough. I had trouble getting it out at first but a little heat did the trick. The output shaft seal was a pain though. The mounting bracket for the diff. partially covers the seal so I had to remove the diff. After getting that out I had a heck of a time getting the seal out. Someone had used an adheasive one the old seal so I had to use more heat than I was comfortable with. Once I got it out getting the new one in was pretty difficult as well. I bent the first one a bit so decided not to use that. The second one I beveled a bit and it slid right in. After that assembly was a piee of cake. The whole job took about 10 hours - considerably slower than it should have been and I still have one rear output saft seal to replace
