01-17-2004, 04:42 PM
As all of you know, our T-case protection is good for a bird bath (when flipped upside down)  I seen our fellow H2 member construct a beefy skid plate out of some scrap U-bolts and metal and it sounded like a great idea. I went into my garage and gathered up the goods. This is how it went.....
The truck is in the garage waiting for a bath and some armor....
Mike - Station 38 Fire Chief -
\'03 Sunset, Lux, Sunroof, Air Suspension, HID\'s, eXtreme Tubes w/ 4 PIAA\'s, Warn 9.5ti winch, SMA HD Brush Gaurd w/ 2 PIAA 525\'s, SMA Valance w/ PIAA 520\'s, Stainless HUMMER Inserts, Gibson SS Headers, Corsa SS Sport e
01-18-2004, 05:05 AM
Excellent job on your design!
You are either single or divorced, or have a really cool wife, for her to let you spend that much time on your Hummer.
I was outbid for the purchase of a plasma cutter from my workplace. I'm dying to get myself one, it is so much easier to use one, than it is to cut it by hand>
Well Done!
Ric-H2
www.meatspin.com
01-17-2004, 04:54 PM
This is the top section of the piece that was just welded. The top plate is cut out for the OEM bolts. With the 3/16" drop, these are able to be counter-sunk so they will not get hung up.
01-17-2004, 04:44 PM
This is the first piece of steel. It is 3/16" plate.
01-17-2004, 07:43 PM
Mike,
DRTY's reply is positive, just constructive questioning. You did a great job! Beef up the bottom of an H2 and you can go anywhere!
Even my H1's belly had some aluminum in there that now resides at a scrap bin I hope. Steel is the only way to go. I hit a rock so hard this week on my steel rockers that half the crap in my truck went flying in to the windshield. That's fun stuff!
01-17-2004, 07:47 PM
I like it and I want one!
Excellent work you did there with the welding and cutting. I probably would have found a way to sever a limb playing with those big boy toys you were using.
S&B Member since '03
01-17-2004, 04:51 PM
This is the first piece welded on the plate. It is about 3" X 9". This will help space the new skid plate another 3/16" away from the t-case when bolted on.
01-17-2004, 06:16 PM
Somebody likes to weld. Instead of adding all of the extra plate for spacing why didn't you use a press to give it a slight bend to accomodate the t-case?
Just wait until a rock scrapes across that thing and lodges in that cut-out logo. I'm curious who you think will be impressed by the logo way under there?
Don't take this wrong, I'm not bashing you at all.
01-17-2004, 04:57 PM
This is the bottom again. The second spacer plate is welded for the rear. This second plate will eventually rest against the torsion cross member.
01-19-2004, 02:53 AM
I got out bid on the Plasma Cutter from work. I lost it over a bid of $350.
I've got about 15 sheets of stainless steel that I want to cut up to make myself some awesome looking undercarriage protection.
I will get me a plasma cutter, and then I will be posting some picts soon.
Ric-H2
www.meatspin.com
01-17-2004, 04:46 PM
With a little help from the Miller plasma cutter, this piece gets cut to 9" X 21"
01-18-2004, 04:10 PM
What Model? I have an older Cutmate 300 I picked up for $500, 3/8"s clean, 1/2" to 5/8"s sever. It also needs air as well. I set up a Motorguard M-60 Air Filter for it to insure a clean dry supply of air.
BS Member since '04
Founding Member of RCRC 4wd Club Scaramento, CA www.rcrc4x4.com
Pirate4x4.com Vendor & Toyota Truck and 4Runner Talk Forum Moderator
01-19-2004, 12:28 AM
Can you make me one??
R2
Front Locker, Stealth winch, 37" Super Swampers SSR,low center of gravity = Ultimate H2
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
01-18-2004, 12:19 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by RIC-H2:
Ric-H2<HR></BLOCKQUOTE>
Thanks Ric. Actually I have a really cool girlfriend. She just puts up with me
As for the plasma, you NEED one. My Miller is good to cut up to 5/8" and requires air. I think I paid about $1100-1200 for it.
01-18-2004, 01:46 AM
Nice work, gota love Plasma! I love mine!
BS Member since '04
01-17-2004, 05:06 PM
Its got some paint now... On each end of the new skid, I heated it up (red hot) with a torch and bent the ends. This gives the new skid plate a rise on each end so it tucks up towards the floor of the truck. Now the ends will not be able to get hung up.
01-17-2004, 05:13 PM
This is the top view of the skid plate. It is still glossy because its wet! Its actually flat black primer. Now the explination on the mounting. You can notice the 3 holes with a notch on one end. This is the OEM bolt pattern for the front. The notch in the plate is to clear the other OEM cage under the motor. I only used 2 bolts for the rear. I drilled these 2 holes through the front side of the torsion bar cross member. The holes are drilled in the part of this cross memeber where it makes a small "U" shape at the bottom of the steel. The rest of the skid plate extends to the back part of the torsion bar x-member, to cover it up.
I will get some pics of this new plate installed so you can see the complete product. Hope you enjoy!
'03 Sunset, Lux, Sunroof, Air Suspension, HID's, eXtreme Tubes w/ 4 PIAA's, Warn 9.5ti winch, SMA HD Brush Gaurd w/ 2 PIAA 525's, SMA Valance w/ PIAA 520's, Stainless HUMMER Inserts, Gibson SS Headers, Corsa SS Sport exhaust, Husky Liners, 12 Hide Away Strobes, Whelen Dash Dual Strobe, 2 Whelen LED bars, Remote Mount Motorola Low Band, Sho-Me/Whelen Siren, XM Radio
01-17-2004, 04:59 PM
This is the t-case side of the new skid plate. I also welded 1/2" X 1/2" square stock down the long sides for even more support.
01-17-2004, 05:03 PM
Since I was so bored, I had to get a little creative. This H2 cutout is for all the rocks and things you may run over. Now....if they miss the H2 stamped on the front skid plate, they will be reminded, very shortly, that they have been just ran over by an H2. You can also see the rear counter-sink holes.
01-17-2004, 06:02 PM
You've just created a weak point plasma cutting that logo. Excellent idea though.
" S & B Member Since 2003 "
Hybrid Mode
