12-25-2003, 12:56 AM
Big time water leak under driver carpet. Carpet and padding are saturated last two rainfalls. Not sure if coming in from side near sill or under frame (more likely?) Defintely not dripping from above. Any others have this eexperience. WIll bring to dealer next week.
12-25-2003, 01:01 AM
Do you have a sunroof? if so it could come from the roof. The headliner is fiberglass and the water can drain down the window pillars. If you do have a sunroof take some silicone grease or vasaline and put it on the roof around the sunroof. I did this to pinpoint my leak. It was the drain hoses and the glued them on as the clamps did not hold them tight. My leak is gone...
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, B&B Headers and exhaust, 2-7" screens in headrests with DVD player and TV Tuner.
12-27-2003, 01:02 PM
I had this same problem on the opposite side. I had water splaching around in my a pillar/rocker panel. They found a leak in the door tie strap.
12-27-2003, 03:36 AM
That's funny anti:
The chick you live with, your momma, is $50, blows gas and leaks too. I wouldn't do her with your daddy's d&@k.
I guess you are the one load your momma should have swallowed.
Black Lingenfelter Lux
12-31-2003, 04:23 PM
Thank you for your responses. Just got back from dealer. They found leak from weatherstripping on driver side body that had become mispositioned. Replaced carpet padding. Hope this is the end of this problem
12-25-2003, 01:05 AM
Also check the "A" pillar on the driverside. It could be leaking in from the driverside roof light, down the a pillar, through the side of the dash and on to the carpet.
2003 Yellow H2, Lux Series, Air Suspension, Front Brush Guard, Rear Tail Lamp Guards, Helo Maxx 8 Chrome Rims, MC2 Chrome Billet Locking Fuel Door, MC2 Chrome Hood Handles, MC2 Chrome Hood Latches, Chrome Billet Hummer Logo Hitch Step
12-27-2003, 12:04 AM
This is funny, a $50K POS that eats gas and leaks. What a joke.
12-27-2003, 05:29 AM
Don't feed the trolls.
The only reason he is here is to get a rise out of you. If you allow him to do that, he wins. Ignore him and he will eventually go away as there will be no fun in staying.
________________________
Black 2003 H2 - Just like most of yours, just possibly with less crap bolted on.
My job: http://www.HardOCP.com
This place sucks now, bye.
12-26-2003, 11:53 PM
i would be suspicious of the front roof mast (a pillar?) it is easy... right after a good rain... just pop out the handle and take down the inside plastic piece... it will be soaked along the mast... the roof marker light is at fault..
unaslob
Hybrid Mode
