Old 06-07-2003, 03:57 PM
COREY COREY is offline
COREY is off the scale
Is there a trick to unhooking the back seat material so I can run the monitor wire through the back of the seat? I have the Vizualogics where the wire goes through the headrest tube.
Old 06-08-2003, 12:24 AM
TBarrow TBarrow is offline
TBarrow is off the scale
There is a plastic strip holding the seat cover on. I undid mine and reached up and pulled the cable down. I did not cut a hole I fished it down next to the headrest support.
Old 09-17-2003, 02:32 PM
RasterMaster's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PhilD:
I installed the Vizualogic monitors and used a straightened out coat hanger to feed the wire from the headrest hole down to the bottom corner of the seat. No need to take anything off or apart. To be on the safe side I folded the end of the neger over and covered it in tape, to prevent accidentally damaging the vinyl seat covers.<HR></BLOCKQUOTE>
PhilD,
How did you remove headrests? I picked up the neoprene seat covers which has holes that the headrest "poles" fit into. Any help would be greatly appreciated!
Regards,
RasterMaster
Check out the OkC Chapter Page!
Old 06-08-2003, 12:00 PM
Thanks for the info TBarrow .....
Old 09-17-2003, 08:09 PM
PhilD,
Thanks for your help. DirtyFun was in chat and told me the same thing. Seat Covers went on tight, but I got them on today! Will post pics tomorrow.
