Old 10-08-2003, 01:43 PM
SRFCASTR SRFCASTR is offline
SRFCASTR is off the scale
Can someone clarify (I did look into past threads without finding an answer) whether an Air Horn can easily be hook up using the Air Susp. Pkg. compressor????
Any suggestions for which to buy in this scenario???
Any install brilliance you can shed on it would also be appreciated.
SRFCASTR
Old 10-08-2003, 02:51 PM
DURAMAX TIM is off the scale
I haven't looked into it but we have an air hose to hook up in rear so it u tee into this line it would act the same as using the factory hose.
Get your hose out and do some testing and put a gauge on it to see what pressure u have.
Depending on the horns some need more air flow than others and a tank up front will help this.
U could hook the horn/horns up to the inflater hose and see if it works OK.
I mounted a Pete air horn on the outside of the garage, this will get people's ATTENTION.
98 ZR-2 Blazer
Ex H2&3 owner
SRFCASTR
