08-06-2005, 01:33 PM
What would it tale to make the rear diff lock in 4HI or really anytime I want? This would be usefull for higher than 20mph wheel speed mud crossings.
\'06 H3: Slate Blue, Lux Cashmere, OffRoad, Auto, Sunroof, XM, Rails, Racks, and Guards.
08-06-2005, 02:14 PM
Are there a lot of those in West Palm?  Just messin--I'm not sure what would have to be done technically...
08-13-2005, 01:01 PM
I don't reccomend bypassing that. GM did that for a reason. When that lock is on, your rear axle is locked solid. When that thing is locked solid, something has to give when the rear tires are not spinning at exactly the same speed, and the faster you go the more likely is that it will break something in the rear axle. And if you bypass it and break something, you can forget about warranty covering it. I haven't experienced a time yet in which you need it above 20mph.
08-13-2005, 07:58 AM
Jeep Rubicon has the same problem, I just learned that there is a cure for it through an electrical bypass surgery  which tricks the onboard computer into thinking the vehicle is engaged in 4LO when it is still in 4HI, and ...voila, the diff-lock will engage.
I am still investigating on how this can be done on the H3, will let you know of any findings. on the Rubicon, I heard it's a simple wire bypass in the dashboard.
DuneH3
08-15-2005, 06:10 PM
I was curious if he is American. I wouldn't change any attiude toward he no matter what nationality he is. Just curious. OK?
08-15-2005, 06:44 PM
I was wondering if he was American military myself. I have a friend stationed with the Navy in Dubai.
08-15-2005, 05:16 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MxHonda:
What would it tale to make the rear diff lock in 4HI or really anytime I want? This would be usefull for higher than 20mph wheel speed mud crossings. </div></BLOCKQUOTE>
As far as I know there is a "4Hi Locked" option in my H3, so if you want to make the rear diff lock you just push the button...
\'06 Boulder Gray H3 / Loaded
08-13-2005, 01:36 PM
HummerTech, you're absolutely right, I assume I was addressing myself to an offroad skilled audience  only a novice beginner would engage diff-lock and go at high speeds and ultimately break the diff altogether.
In certain situations, SPECIALLY in soft Desert dunes you have to travel between 5 and 12 MPH, however, TORQUE is not what is needed to climb a dune, it's Horsepower. AND you also need diflock at the same time when tackling endless dunes one after the other (axle articulation). I think in the US you guys experience the same situation when in mud terrain where an extra speed to help you get accross is needed.
In soft sand we always use 4HI we only switch to 4LO when we are in trouble and need that extra push.
Another thing I didnt like in the H3, the Stabilitrac was engaging by itself without "asking me" (heheh) I didnt like that because it was cutting power to certain wheels where I needed the power the most. Putting the vehicle in control instead of me. Offroaders HATE that. Onroad put whatever system you want, we'll play along, but Offroad, we have to be in charge.
coming back to your point, you're right and I'm right. Engaging diff-lock in 4HI is only for experienced people who know what they're doing and know WHEN to use it. A skilled evaluation of the terrain is necessary here.
DuneH3
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummertech:
I don't reccomend bypassing that. GM did that for a reason. When that lock is on, your rear axle is locked solid. When that thing is locked solid, something has to give when the rear tires are not spinning at exactly the same speed, and the faster you go the more likely is that it will break something in the rear axle. And if you bypass it and break something, you can forget about warranty covering it. I haven't experienced a time yet in which you need it above 20mph. </div></BLOCKQUOTE>
08-15-2005, 05:02 AM
That's cool Dune. Mudbogging sometimes does require a locked rear and speed. Typically, there is enough slippage in deep mud to avoid damage. Of course one has to be careful when the rear is locked at higher speed.
Running a spooled or locked rear on the road can be dangerous.
08-13-2005, 07:11 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by hyperion78:
y? what difference would it make? </div></BLOCKQUOTE>
hehe, you're right Hyperion, I dont want to go off-topic here, but if it's necessary to make intros, here goes : I am 1/2 Lebanese 1/2 French living in the UAE as an Expat.
GM has its regional office here in Dubai and I am a contractor for GM for various Hummer offroad issues. I am also a member of the press.
Below is my picture during the regional launch of the H3 held in Bahrain back in May. I am the short guy standing next to Terry Johnson, GM's Regional Director for Middle-East and Africa (Based in UAE)
I registered on this forum to pick your brains from time to time and share my experiences with you....if that's ok
Regards.
DuneH3
08-31-2005, 01:41 AM
I read in the manual that you can have the 4 lock hi up to 70 MPH - not recommended on roads above 30 MPH for a while.
08-06-2005, 02:55 PM
Are there a lot of those in West Palm?  Just messin-- </div></BLOCKQUOTE>
That's funny  About 15 miles west of Palm Beach we have the Corbett Wildlife Preserve and it is filled with water holes and mud. Some do require some speed to get accross. Ocala National Forest is about 2hrs North of us and I would like to go there sometime too.
I am sure that I will MANAGE to make it through with the stock H3.
08-13-2005, 03:37 PM
I can't say I'm familiar with driving over in UAE. But I do need to ask this question. Are you an American living over there?
08-13-2005, 03:58 PM
Hybrid Mode
