Old 05-19-2006, 05:56 PM
tbuckley's Avatar
tbuckley tbuckley is offline
tbuckley is on a distinguished road
Default Tire Size
Just installed some 37" BFG All-Terrains... for giggles I put a measuring tape on them... the height actually measures 35" -- barely. How the heck do tire manufacturers calculate their measurements... I neved did check the actual tire size of my old 35"s. Just curious...
May your glass be ever full.
May the roof over your head be always strong.
And may you be in heaven half an hour before the devil knows you're dead. ~ Irish Blessing
Old 05-19-2006, 07:02 PM
MarineHawk's Avatar
Default Re: Tire Size
Are you measuring the ones supporting the vehicle? If so, the bottom of the tire is deformed.
Old 05-19-2006, 07:35 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
I want to go with 37"s also but was told the fronts might rub? is this true?.....do you have any pictures?
Old 05-19-2006, 08:23 PM
MarineHawk's Avatar
37"x13.5" Cooper STTs.
Old 05-19-2006, 10:15 PM
They'll rub just a little as you can see in hawk's pic. Nothing to worry about.
Old 05-20-2006, 05:00 AM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
My 35's rubbed in that spot before I got the weld rims.
Old 05-22-2006, 05:54 PM
tbuckley's Avatar
Originally Posted by PhilD
Several factors will effect actual height, mainly; the weight of the vehicle, the tire pressure and rim width. Manufacturers will measure the tire without any load on it, sometimes at max psi and the height will be for a specific rim width. Add a load, lower the psi, and/or use a different rim width and your measured height will be different.
My 38's only measure 36.75" when on the vehicle.
Phil -- THAT was the help I was looking for. I figured that pressure, load weight, rim size, etc. would account for various standing sizes. Appreciate your help. The rack and ladder look fantastic -- thanks! Rancho lift went on great... I'll submit pics ASAP.
