Old 05-22-2006, 02:14 PM
JMVH2 JMVH2 is offline
JMVH2 is off the scale
Default Water leak
After 11 trips to the dealer for a water leak, that all the time they were blaming the roof lights markers now they told me that water was coming in from the door hinge bolts ! Have any one of you experience the same leak?
Old 05-22-2006, 04:17 PM
Spike Spike is offline
Default Re: Water leak
I had a leak on the passenger side coming from the rubber grommet where the wiring harness goes into the door jamb. They replaced the grommet and dried out the carpets. Good as new.
Old 05-22-2006, 08:12 PM
Black RTV around the bolts and do the same around the ALL the marker light grommets.
Old 05-22-2006, 08:15 PM
I have the same deal. Dealer "ordered parts" all new gaskets I guess. Parts are in so we shall see if it fixes it or not.
Old 05-25-2006, 01:26 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
i had water dripping in from that vent-looking thing on the headliner above the drivers seat....WTF is that thing anyway? and why is it drippin'??!!?!?
Old 05-25-2006, 01:27 AM
roof's water drain
Old 05-25-2006, 01:48 AM
Fubar's Avatar
Fubar Fubar is offline
You're joking right??
Just in case you're being serious, it's the speaker grill for onstar. If it's dripping seek immediate help Big brother is crying
Old 05-25-2006, 05:10 AM
Field Rat's Avatar
Field Rat Field Rat is offline
Field Rat is off the scale
I found water under my floorboard on the driver's side. The carpet and padding were wet. Also the side wire "gutter" was filled with water. I thought it was from my marker lights. I took off the cover to the A piller, no water, dry as a bone. I checked the roof liner, no wetness at all. I poured water into the sun roof gutter to see if it came from a cloged drainage line, they all worked fine.
After I dried out the vehicle, I shut the doors, and sprayed water with a plant sprayer on a hose. I sprayed around the lights, the sun roof and door seal. I did this with the a-pillar cover off, the door jam sills off, and the carpet pulled up.
I found that the very top seal above the door was allowing water through. I opened the door directly after spraying the water. This water went from the top seal, into inner seal that surrounds the inside of the door jam. this water leaked into the wire "gutter" next to the drivers seat. It was allowing a large amount of water in. During a heavy storm, it saturated the carpet.
I put clear silicon sealant along the underside of the top seal all the way to the front and back of the door.
Result, no more water in the floorboard.
I will attach photos if anyone needs me to.
\'97 H1 Green Soft Top SOLD
\'03 H2 Pewter SUV= SOLD
\'05 H2 Desert Sand SUV
\'05 H2 Stealth Gray SUV
Old 05-25-2006, 09:01 PM
H2 Bill H2 Bill is offline
I would like to see a photo of how you did it!
Thanks.
