05-23-2006, 09:36 PM
Question for f5fstop
My H3 has 1400 miles and the rear engine seal is leaking. I did change to Mobil1 and they say Mobil1 can always find a leak. The leak is a small drip coming from the rear seal down to the rubber plug under the seal and flywheel. Will the engine need to be pulled to replace?
Thanks for your advice
Yellow Lux H3, w/Adventure Pkg, Borla, K&N.
05-23-2006, 09:59 PM
Re: Question for f5fstop
I had a leak from my front seal at about 2200miles. The dealer said that it was due to a production nonconformity. They did not have to pull my engine, and it was all under warrantee. It doesn't matter what oil you use there should never be a leak.  I am actually switching to AMSoil 5w30 with my next change. I've used it before and it's killer stuff.
05-23-2006, 10:16 PM
No, the proper procedure is to pull trans/tcase, not the engine.
05-24-2006, 12:10 AM
X2
As for the leak being from synthetic oil, tell them they are full of BS. Oil is oil, Mobil 1 meets AND EXCEEDS the GM requirement, and there should be NO leaks. Not that hard to remove T/case and trans on the H3, and then remove the flywheel and install a new rear seal. Probably not installed correctly in the plant. Not a big problem, but like axle seals, some will leak until repaired.
05-24-2006, 12:16 AM
Thanks for the information. I will take it in tomorrow to the dealership and see their actions.
05-30-2006, 03:14 PM
I developed a leak from my engine rear main seal at 2400 miles. I agree with f5fstop "Not that hard to remove T/case and trans on the H3, and then remove the flywheel and install a new rear seal." My brother is a GM mechanic and did the job for me. Everything was covered under the warranty. I have been running with Mobile 1 ever since with no more leaks.
2006 H3, Black, Luxury, Off Road, Automatic Transmission, Sunroof, Trailor Hitch Package, XM, Mud Flaps, Black Assist Steps
05-24-2006, 09:28 PM
It turns out to be my oil pan seal, not the rear engine seal. The service manager said the pan seals have been a problem. I am driving an HHR loaner. The HHR really surprises me with its HP.
05-31-2006, 12:27 AM
Good old assembly plant quality control. Guy must have been asleep when the gasket material ran out of the drum, and caused a skip in the gasket.
06-11-2006, 01:51 PM
Bad news  .
My H3 is still leaking. The dealer thought the oil pan was leaking and resealed it. I always thought it was the rear seal but the dealer said no. Whatever, its leaking. Any ideas?
06-11-2006, 02:05 PM
Have the dealer add dye to the engine oil, and drive it for a few days. Then they can track the leak path with a blacklight. If it is coming from where the trans meets up with the engine, it is not a pan leak, it is most likely a rear seal. There will be an oil path from where the trans housing bolts to the engine, down to the pan. Unless you drive upside down, a pan leak will not go upward.
Take it back to the dealer and tell them to fix it right, at least the second time.
06-11-2006, 02:21 PM
They said they dyed the oil and tracked the leak to the pan gasket. Looks like a bad pan re-seal job or the problem is the rear seal.
Hybrid Mode
