Old 06-09-2006, 09:45 PM
vador99 vador99 is offline
vador99 is off the scale
Default optima battery
Wich yellow top optima battery fit for the h2?
Old 06-09-2006, 11:45 PM
Default Re: optima battery
I think its these, but you might want to verify with your supplier or someone here that is using one.
YEL34/78 750 Optima 34DTO
RED34/78 800 Optima 34DTO
RED75/35 720 Optima 75DTO
Old 06-10-2006, 01:21 AM
i know yellow top d-34-78 will fit
Old 06-10-2006, 05:14 AM
MarineHawk's Avatar
Originally Posted by PhilD
Mine is a SC34DU - 750 CCA
This is my second yellow top, the first was replaced under warranty as it failed after 3 months. Previously I had a red top which failed after 12 months.
You mentinoed that before. Isn't that abnormal? Even under heavy use, shouldn't a good battery last a few years?
Old 06-11-2006, 12:43 AM
I had a Yellow Top go bad pretty quick, it was within the warranty period and was replaced under the warranty.
Mine is a Yellow 34/78 and it will have a brother in there with him next week. I made a dual battery holder that will hold two Yellow tops and am controlling them with a Hellroaring BIC-95300B isolator/combiner.
Old 06-11-2006, 06:33 AM
dochummer's Avatar
When using a yellowtop, does it require any additional adapters or is it just a straight swap? My oem battery just died again today...4th time since I bought it....
'03 H2
