09-06-2005, 12:16 AM
Do you guys run hand held CBs in the woods, or do you have mounted CBs in your truck.
I have a Uniden that is a few years old I was thinking of putting in - but then thought "why not hand held?" I am sure the range is not as good...but probably as good as one would need.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
12-15-2005, 01:29 PM
MURS might be a good alternative to FRS if enough people start using it. The big advantages I see are more power (up to 2 watts compared to 0.5 for FRS), you can connect an external antenna (can't with FRS, although I think you can with GMRS), and no license is required, unlike GMRS.
I don't know if there is a MURS and FRS combined unit available, but that would be something worth looking at. </div></BLOCKQUOTE>
I take it you haven't stumbled across a reasonably prived MURS FRS unit. Or have you?
'03 pewter base H2
12-16-2005, 02:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dick Renaud:
You got it. And to legally possess a modified ham radio you must have a technician class license and be also licensed member of a MARS group (Military Affiliated Radio Service) anone can join a MARS group (ARMY, Navy or Air Force)if they are licensed Hams. The only time you could legally operate such a modified radio on CB, GMRS, FRS or MURS would be in an emergency. As a side note, if you modify the radio without contacting the manufacturer to get the mod instructions and giving them your MARS license info the warranty is voided.
I am a Licensed Ham and I am joining a MARS group so I can legally possess a modified radio (ICOM-7000) so I have the broad capability in an emergency. </div></BLOCKQUOTE>
Yikes. Sounds like the best approach for a lightweight user is to just get individual CB, GMRS/FRS radios and if MURS is viable in the area a MURS radio as well. Cables cables everywhere.
'03 pewter base H2
12-16-2005, 03:08 PM
It is not easy or cheap. The Tech class license is the easy part. Buy a book, study for a week or two and pay $14 and take an easy multiple choice test. The Mars deal requires taking ecom training and participating in a minimum amout of MARS functions handling ecom traffice etc. The radio setup I have for mobil in my H2 consists of the radio, tuner for the HF, a VHF/UHF ant on the roof and an 8' whip with ball and spring (old CB style) mounted on the drivers side rear quarter panel, cost about $2500. (including grounding, extra rear mounted battery etc)
It works great and in an emergency can transmit at up to 100 watts on HF (and CB) and 50 watts on VHF/UHF (Hummer freqs, GMRS, FRS and MURS).
It is worth it to me because I participate in may ecom functions local and national.
I also travel alot and want every capability I can get in an emergency. It called life insurance.
Your right, the easy solution is get the different radios. You can use a duplexer or triplexor to combine some of the radios to one antenna. All the VHF/UHF can be combined to a small (16') rubber antenna on the roof. The best CB is still the old full length whip and ball/spring which can be tied down with a gutter clip. Or use the firestick mount in an earlier post.
09-07-2005, 07:24 PM
Kewl. How did you mount your antenna and what model antenna are you using?
09-09-2005, 12:39 AM
Hey Phil, where can I get a couple of those hinged brackets from? I need two for my SUT and one for the H3.
12-16-2005, 01:36 AM
Yeah, it's called a modified Amateur radio!  It's just not type accepted by the FCC though.
M101A2 Trailer
12-16-2005, 11:21 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Beastmaster:
</div></BLOCKQUOTE>
So is there no such thing as a multi-band radio that is a "unmodified FCC certified FRS unit" per FCC regs?
'03 pewter base H2
09-07-2005, 04:51 PM
We usually use FRS/GMS at Paragon.
The most popular CB seems to be the Cobra with the remote, underdash, box so all you see is the mic. </div></BLOCKQUOTE>
That's what I have and love it! COBRA 75SW XT I have a dual antenna set up, but with the trails around here, the trees take them off. so I tend to use the Motorola FRS/GMRS. they work well as long as you are close by. It's good to have both.
09-07-2005, 11:23 AM
..... some toilet cut it off my truck! </div></BLOCKQUOTE>
12-16-2005, 02:30 PM
09-07-2005, 04:20 PM
Anyone thought of installing Marine VHF's
09-06-2005, 01:37 AM
09-06-2005, 12:35 AM
I try the hand held CB Radio, and it just would not work for the trails, the range was very poor. I then went with a FRS/GMR Radios and they work very well and the range is very good on them. I and now thiking of mounting a CB Radio.
09-06-2005, 05:31 PM
I used to run my Uniden with a K40 antenna, but some toilet cut it off my truck!
09-06-2005, 05:37 AM
vtstomper, a good CB to have is a Cobra 29. I have had good luck with them.
09-06-2005, 05:30 PM
I have the RadioShack hand held, and use an external mag mount antenna. I also, remove the battery (power it via 12V), and hook the small top part to a L-bracket atached to one of the dash, center panel, chrome bolts. I bought an extended mike/speaker which is easier to handle. Works great, good reception/power. And if I want the portability, it's there.
Ric
Hybrid Mode
