Old 07-19-2006, 01:10 AM
Alex13188 Alex13188 is offline
Alex13188 is off the scale
Default Water Wetter
Just curious if anyone has used water wetter in their h2 to bring the temps down. I have used it in other cars with great results and was just curious if it is safe to use in my h2. My temps are running a little higher then normal and i was hoping this would help.
Old 07-19-2006, 02:28 AM
Motohead's Avatar
Motohead Motohead is offline
Default Re: Water Wetter
I have only used it in my trackbike. I wouldn't suggest replacing the antifreeze with it, but maybe adding it to the antifreeze.
Old 07-19-2006, 03:35 AM
tomp's Avatar
tomp tomp is offline
How much of a difference does it make Alex?
Old 07-19-2006, 06:51 PM
I dont know how much difference it would make in an h2 but in the past i have seen it lower temps by as much as 15 degrees.
Old 07-19-2006, 06:55 PM
first, check with someone. For some reason I have it stuck in my head that you can't add water to dexcool or whatever the hell is in our systems.
maybe it's in the manual
Old 07-19-2006, 07:20 PM
Its not acctually water its a coolant additive, the company says you can add it to anything but i figured i would check here first.
