Old 07-20-2006, 12:21 AM
Default Weird noise in cargo area
Just started this afternoon. Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I brake hard or go over a bump.
Old 07-20-2006, 12:43 AM
Default Re: Weird noise in cargo area
Luggage area, or could it be from one of the rear doors? I had the Styrofoam type squeaking on my Utah trip over rough roads.
Old 07-20-2006, 12:44 AM
Does it have a weird odor????
Old 07-20-2006, 12:51 AM
Are you asking if the noise has an odor?
Old 07-20-2006, 01:08 AM
I thought you said nose....sorry
Old 07-20-2006, 01:19 AM
check that spare tire is tight and check jack compartment . if nothing found crank the tunes
did you have sex in the back ? you probably busted the suspension
Old 07-20-2006, 05:57 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Originally Posted by Sewie
...Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I am hard or go over a hump.
I know what rubber on rubber on plastic sounds like, but not rubber on rubber on rubber on plastic. Sorry I couldn't help!
