07-29-2006, 03:05 AM
Custom Gauge Cluster?
I was curious if anyone knows where you can order or customize a custom gauge cluster for the H2? I want to get white background gauges with a red/pink led dials...
I would appreciate any help!
Carless... riding the bus...  Trying to decide on which 08 H2 to get
08-02-2006, 12:54 AM
Re: Custom Gauge Cluster?
Street Beat Customs sells them. They are made by US Speedo. I went with the stainless steel back ground with the blue dials (to match my 06 Pac Blue Limited Edition). Make sure that you get one for the 2006 model. 2003-2005 won't work right. I should have my truck back tommorrow. If you want a pic of how it looks, let me know.
07-29-2006, 06:35 PM
We can order them for you. I have done a few recently with white gauges/reddish lighting/ and silver trim sort of like the escalade cluster. Install takes less than 10 mins.
07-30-2006, 01:09 AM
10 minutes? Any chance you have the instruction handy Kodiakz?
07-30-2006, 01:31 AM
Pull the lefthand vent piece off, loosen the hex bolts on the radio shroud and pull it out a bit, remove the hex bolts in the cluster shroud and remove the shroud, remove 4 7mm bolts holding in cluster unplug and remove. Replace in reverse and call it done!
08-02-2006, 03:58 AM
Originally Posted by PhilD
I suspect that is for a complete dash pod swap, which is just undoing a few bolts, and swapping the complete unit out. I don't see how you could do that, then pull the unit apart, swap the dash face, assemble everything, put it all back in, in 10 minutes, but I could be wrong...
Kodiak drinks Red Bull before his installations.
Hybrid Mode
