12-17-2005, 02:37 PM
Are there any magnetic paint protectors available for 3's yet?
Slate Blue-Adv., Lux, XTC Lightbar, Sunroof, XM, you name it...
12-20-2005, 03:39 PM
I believe the problem with these is that they do not stick to the fenders. At least that is what I recall reading somewhere.
12-20-2005, 08:03 PM
They said it was 24" wide but I did forget to ask if this was the plain stock price or not.
12-20-2005, 05:08 PM
Did you have it custom done at a national chain shop or just someone local? I don't recall if it was the clearbra or the other brand I looked at but they did not have a dealer down here.
12-20-2005, 03:49 PM
The fenders are fiberglass, duh. Magnets won't stick to them.  </div></BLOCKQUOTE>
Yep
3M makes a clear auto protector you can use for the fenders. Check with Timgco. I'm sure he knows about it. </div></BLOCKQUOTE>
Didn't fstop start to put the 3M protector on a while back and found it didn't match the fender?
12-20-2005, 06:40 PM
You might want to see this POST
If you feel like a do-it-youself-er you could try THIS
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
12-20-2005, 07:07 PM
i also have 3m...its on my hood, fenders, doors, and rear quarter.
i might add some more coverage to those areas which already have it.
12-20-2005, 07:44 PM
3M clearbra is on Kira. We didn't buy a kit. we had it done custom. We did the main impact areas on the breasts and rock sliders. It's doing it's job. There are a couple of marks in the rear fender flare where the lube didn't quite cover. WELL WORTH IT! </div></BLOCKQUOTE>Fissed
Oh man, I just couldn't resist!!!! </div></BLOCKQUOTE>
LMAO! Wait until she views this post!
12-20-2005, 07:11 PM
Just called the Fast Signs that I do a fair amount of business with and they said $6 a square foot for the magnetic material. Based on previous dealings I think they would probably even come down some on that.
12-20-2005, 10:00 PM
The shields for the H2 come in two pieces each for the doors. Upper and Lower. The most inportant areas to tape are the leading and trailing edges. After you've done it a few times it only takes about 30 minutes at the most.
12-17-2005, 07:03 PM
The only one's I've seem were homemade. They'll be out soon though I bet.
12-20-2005, 03:55 PM
Hall Hummer used a CLEAR 3M product on one of their trucks. It looked great. I can get more info if you'd like.
12-20-2005, 04:14 PM
Looked into the 3M and another brand a while back and they look like the best option for the H3. Would be nice to have the magnetic shields for the rest of the side panels as well. </div></BLOCKQUOTE>Yep, you're right. You could make them. Painter's tape holds them on well enough.
12-20-2005, 04:06 PM
12-17-2005, 05:42 PM
ive seen them but i cant find em either. i'll keep looking and let u know if find them.
12-20-2005, 10:07 PM
Curiosity got this cat. I measured them. The tallest is about 22".
This is Oldhiker's truck. He uses Painter's tape.
12-20-2005, 05:16 PM
12-20-2005, 03:32 PM
Try the OEM mudflaps, they seem to help some assuming that you are using the base/luxury 32" tires or the Adventure 33" tires.
12-20-2005, 03:43 PM
I believe the problem with these is that they do not stick to the fenders. At least that is what I recall reading somewhere. </div></BLOCKQUOTE>The fenders are fiberglass, duh. Magnets won't stick to them.
Hybrid Mode
