Old 08-08-2006, 09:48 PM
lexunet lexunet is offline
lexunet is on a distinguished road
Default Difference between 4High and 4High Lock
New H3 owner. I know this is probably a dumb question. If the H3 is full time all wheel drive, what is the difference between 4 High and 4 High Lock? I have a base model without the locking diff.
I also used 4 Low Lock the other day. The trans was pretty darn loud. Is that normal?
Old 08-08-2006, 09:56 PM
Default Re: Difference between 4High and 4High Lock
Anytime you want to do more than 25MPH, 4 hi lock. Under 25 MPH, 4 lo lock.
4 lo lock in 1st or 2nd gear. Very noisy.....normal.
Old 08-08-2006, 10:02 PM
Thank you for the reply. What about the difference between regular 4 High and 4 High Lock? Again I have a base model w/o the locking diff.
Old 08-08-2006, 10:15 PM
Field Scout's Avatar
Field Scout Field Scout is offline
Field Scout is on a distinguished road
4 hi power distributed approx 40/60 f/r open diffs 4 hi lock 50/50 center diff locked equal power all four wheels
Friend of T&A
Old 08-09-2006, 04:02 AM
X2
i was gonna say that
Old 08-08-2006, 10:25 PM
4 High Open - provides a constant 40%/60% front/rear torque split
4 High Lock - allows a 50%/50% split front/rear for more slippery surfaces
Old 08-08-2006, 10:31 PM
Thanks. Good to know!
Old 08-08-2006, 10:40 PM
Welcome lexunet!
Whereabouts in CA are you?
Old 08-11-2006, 05:37 AM
Michael1 Michael1 is offline
Location: Northwest of Los Angeles, just outside all the traffic
Michael1 is on a distinguished road
Technically, there is no torque split when locked, because it is no longer a differential. For example, if the front encounters a slippery surface, torque will be transmitted to the rear up to 100%, and vice versa.
Michael.
Old 08-11-2006, 06:10 AM
Big Z Big Z is offline
Two things comes to Mind!
1. WTF were you thinking With? ----Pretty Damn Loud!----- in Low LOCK!
2. The **** eating Grin Must of Affected the Thought process!....
READ YOUR MANUAL!!!
Old 10-03-2006, 07:31 PM
Dirt Good. Detergent Bad!!
