Old 08-17-2006, 08:22 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Default CB Antenna - Firestik help needed
I installed a 4' Firestik cb antenna on my rear bumper and ran it into the center console. I cannot tune this thing for the life of me! It's a "trim to tune" and I've trimmed and trimmed like they say and the meter wont go down anymore to where it should be.
Does anyone esle have this type of antenna that could offer some assistance?
Thanks!
____________________________
Old 08-17-2006, 08:26 PM
ree's Avatar
ree ree is offline
Default Re: CB Antenna - Firestik help needed
Throw it out and buy a FireStik II or FireFly series antenna that you can tune by hand with the knob at the tip. It won't be more than $15-20.
Otherwise, have you talked with the vendor you got it from or called up FireStik (602-273-7151 / http://www.firestik.com/b4email.htm) to see what they have to say?
'03 pewter base H2
Old 08-17-2006, 08:39 PM
Mike E's Avatar
Yea, I was wondering about the Firestik II. Do you think the 4' length is ok for the rear bumper? I was reading about how the back of the truck could cause a signal problem but I have seen others with the same setup.
Old 08-17-2006, 08:47 PM
Beastmaster's Avatar
Beastmaster is off the scale
Get yourself a longer antenna. 4' will not give you adequate coverage to run the antenna without reflecting at least 20-30 percent of the signal back to itself because of it's proximity to everything.
M101A2 Trailer
Old 08-17-2006, 08:57 PM
Mike E's Avatar
Do you think I would be better off mounting to the roof rail and stiking with a 4' firefly or firestik II?
Old 08-17-2006, 09:01 PM
ree's Avatar
ree ree is offline
Yes. Using as long an antenna as possible up on the roof is the best plan. If you park in a garage a 4' will be long and hit your door and drive throughts. So unless you use it 100% of the time, invest in a fold-down mount that you can use when parking, etc.
'03 pewter base H2
