Old 02-11-2005, 01:21 PM
finbox finbox is offline
finbox is an unknown quantity at this point
On my truck when you press the slide open button the sunroof stops with the roof 4 inch's from fully open, then if you press it again it will slide about 3 inch's more and 1 inch is showing, and if you press it again it will go all the way open (the roof is all the way in, and does not stick out in the opening at all).
Is this the same as everybody else?
Please check it out for me,
Thanks,
Finbox
Thanks,
Finbox
Old 02-11-2005, 04:18 PM
LasVegas LasVegas is offline
LasVegas is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by finbox:
Ok i just read the manual and this is normal....
Why are there so many stops? I think it sould just open all the way.
With LV's auto open mod, will it open all the way or to the first stop? <HR></BLOCKQUOTE>
Mine is a '03. Some of the '04s seem to be a bit different with stops as you mentioned. Check the manual. Maybe these stops can be programmed. I don't know how my mod will work with yours.
Jonahs
Old 02-11-2005, 02:10 PM
Tully Tully is offline
Tully is off the scale
do you want water on your head?...are you SURE you want water on your head???...FINE! WATER ON YOUR HEAD IT IS!
Old 02-11-2005, 01:36 PM
