Old 08-31-2006, 04:16 PM
31_bandits's Avatar
31_bandits 31_bandits is offline
31_bandits is on a distinguished road
Default A question about the FJ
Does the FJ have a locking center diff?
She makes me wanna feel
She makes me wanna try
She makes me wanna pull a star from the sky
Old 08-31-2006, 07:40 PM
Wisha Haddan H3's Avatar
Default Re: A question about the FJ
Short answer = yes
Long answer from cars.com ...
"The manual has permanent 4WD for use on any surface, with a limited-slip center differential that sends 60 percent of the torque to the rear axle in normal driving. It can automatically transfer up to 70 percent back there, or a maximum of 53 percent to the front axle when slippage occurs. The transfer case lever can be used to lock the center diff for a 50/50 split, and to engage an additional low gear for off-roading. In normal use on snow and wet pavement, automatic mode should be more than enough. The 50/50 lock might help when stuck and in low gear.
The 4WD that's teamed with the automatic transmission is actually less sophisticated. Rear-wheel drive is the default mode. Here the transfer-case shifter engages a part-time, 50/50-split 4WD that's for use only on slick surfaces. (Dry pavement causes binding and possibly damage.) Another setting engages the low gear for off-roading. A locking rear differential, controlled by a dashboard button, is optional."
http://research.cars.com/go/crp/research.jsp?revid=50301&makeid=47&modelid=7838&ye ar=2007&revlogtype=20&section=reviews
also, they only mention locking rear diff with the auto trannys, but it's available on both.
Old 08-31-2006, 07:51 PM
31_bandits's Avatar
Originally Posted by Wisha Haddan H3
Short answer = yes
cool. thanks, man.
so "yes" for the manual, but "no" for the automatic are the answers to my question.
Old 08-31-2006, 09:33 PM
I think it's yes for both. If the center diff was open (or ltd slip) on the auto tranny, there would be no binding on dry pavement.
Old 09-01-2006, 02:07 AM
31_bandits's Avatar
well, in the eBrochure, on page 3 it mentions a locking center diff for the manual, but not for the auto. And also lists locking rear diff as "standard", so that yields 3 wheels forced to spin, which is pretty good.
So i think you get's an open center with the auto. I will concede that that seems somewhat odd.
Old 09-01-2006, 03:09 PM
meathead meathead is offline
meathead is on a distinguished road
Correct, the auto only comes with a rear locker.
